HID installed now no HI beams?!?!
I just finished installing HIDS that are HI/LOW beam. It was a PNP kit and I am pretty sure I have them wired correctly, however only the low beam works, and it is acting like I have my high beams on. (blue light on dash is on) When I go to use the HI beams, all it does is flicker like a strobe light. Do I need to upgrade my fuses in order to correct this, or is there something that I need to do to fix it?
where did u get the kit from cause i ordered a kit from here https://honda-tech.com/zerothread/2044932 and i couldnt figure out how to wire the three prongs ...the hi's would be on and the lows would be off or vise versa
i had the same problem u have ...cause they didnt send clear instructions on how to wire up the kit...i got tired of going through trial and error and never got it fixed so i just only have low beams.... lmk if u fix it
