ZEX nitrous kit on gsr
Old Feb 15, 2008 | 09:39 PM
kahwhy's Avatar
Default ZEX nitrous kit on gsr
so i just installed a nitrous kit on my car and its a 50 shot.. do you guys think itll damage my motor with its stock internals...and do i have to retard my timing or just leave it, will it affect my performance.. and one more thing can a VAFC 2 help with getting more fuel instead of adjusting my timging.... thanks...
Old Feb 16, 2008 | 05:46 AM
sh4mr0ck's Avatar
Default Re: ZEX nitrous kit on gsr (kahwhy)
I haven't installed nitrous on my GSR yet, but from what I've heard it's the best bang for the buck and you can do it with stock internals, so it shouldn't hurt your engine and you shouldn't have to adjust timing as far as I know...
I don't have any experience in the nitrous field, though, so probably shouldn't take my word for it...
Old Feb 16, 2008 | 06:46 AM
Rikter's Avatar
Nitrous is not the best bang for your buck as it's a renewable power source... i.e. you have to continually fill up the bottle all the time.
I hope you got a nitrous bottle heater too as keeping nitrous at optimum temperature will help you get the most of out it.
I would recommend two stage colder plugs at the least.
-Rik
Old Feb 16, 2008 | 06:50 AM
jhammond_82's Avatar
Reject Papi
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous is not the best bang for your buck</TD></TR></TABLE> what other power adder gives you 100+ hp for 500 bucks? yes you do have to refill but who cares. i think that nitrous is ok as long as your not hitting it everyday. it makes for a great sleeper, no fmic to let people know what your packing. its cheap and effective.
Old Feb 16, 2008 | 02:04 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (jhammond_82)
I'm guessing this is a dry kit?
With a 50 shot you should not have to take out timing so you should be good in that area. As long as you keep it at a 50, go any larger of a shot and you will need to take out timing.
A VAFC is helpful to your nitrous system you can add more fuel to go along with that nitrous. You can add some extra fuel when you spray, throughout the duration of the spray and a bit extra at redline, although too much will make ur car run like poo!.
Get some Zex plugs they will do just fine.
Your motor will blow up if you use it ALL THE TIME so be nice to your stock motor!
Old Feb 16, 2008 | 03:57 PM
vsmdc4teg's Avatar
So you put the nitrous kit on your car and now ur asking if its ok to run it on ur stock motor?
Wrong sequence of events there buddy. Maybe you shouldnt have nitrous if u dont know anything about it
Old Feb 16, 2008 | 10:47 PM
slowassgsr's Avatar
I don't know much about nos systems, but do you tune nos like any other power adder?
Old Feb 16, 2008 | 11:04 PM
Jimmy's Avatar
Global Moderator
Is this on a dry or wet kit??
IMHO, i wouldn't run nitrous.. due to the longterm effects on your engine..
But if your going to run it..
I'd run a cooler spark plug, retard the timing just a little and add a little bit of fuel on the VAFC just to be on the safe side..
There's a quote for nitrous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">nitrous is like a hot chick with an std, no matter how bad u wanna hit it, u kno somethin bad is gonna happen.</TD></TR></TABLE>
Old Feb 17, 2008 | 10:26 AM
98gs-r's Avatar
Default Re: ZEX nitrous kit on gsr (sh4mr0ck)
i think the stock gs-r internals are 26% stonger than the ls gs rs and i have heard of people running nitrous on those with no probs but i am not 100%sure just dont use it all the time
Old Feb 17, 2008 | 11:30 AM
vsmdc4teg's Avatar
^ No there no stronger than the internals from a b18b
BojeEM2
Honda Civic (2001 - 2005)
14
Sep 12, 2007 02:13 PM
B!^A@
May 29, 2007 07:31 AM
0618turbocivic
Jul 25, 2006 08:38 AM
TypeR-R6
Aug 2, 2002 02:28 PM
ridnmyhonda
Jan 9, 2002 06:38 AM
