swap problem please help
Old Feb 15, 2008 | 04:25 PM
LsScivic's Avatar
Default swap problem please help
ok i swaped a ls in my civic hooked everything, up got it running, put the axels in. went to move it and it wouldnt go in to any gear without extreme force. when the car isnt running there is not problem. i was told it was my slave cylinder so i relplaced it still the same problem. so im seeing if this has happened to anyone or just an answer to fix it. thanks
Old Feb 15, 2008 | 04:30 PM
LsScivic's Avatar
bump someone has to know
Old Feb 15, 2008 | 04:33 PM
nautique196's Avatar
Default Re: swap problem please help (LsScivic)
so im guesin its a hydraulic unit, check for leaks ne where. make sure its connected good. did u put fluid in it? does the pedal feel really soft, no resistance against it, if so thats probably the problem.
Old Feb 15, 2008 | 04:43 PM
LsScivic's Avatar
theres no leaks i bled it it had tons of pressure then i started it moved it a foot and then it was soft really soft so i dont know i was told told there was a chance a slim chance that i could be my throw out bearing?
Old Feb 15, 2008 | 05:16 PM
LsScivic's Avatar
Default Re: (LsScivic)
bump someone else has to have an input
Old Feb 15, 2008 | 07:06 PM
96electronH's Avatar
before you go thinking about your t.o.b. did u replace the clutch master cylinder those things can get gunk all through the system?
Old Feb 15, 2008 | 07:15 PM
MilanoRedCoupe's Avatar
I once saw a kid put together an engine and transmission without putting the throw-out bearing in...
Old Feb 15, 2008 | 07:38 PM
LsScivic's Avatar
well before i started the swap i drained all fluids gas,brake fluid,clutch fluid,everything just for that sole fact. as for not t.o.b. being installed i got the gsr tranny off a friend i personally helped pull out the swap in witch ran and moved fine before bull out then i seperated the tranny from the block and picked up the ls slaped them together. so i dont see it being those i think it might just need a better bleed but i want to cover all bases and make sure theres no ghost that i dont know about.
hiphop23j
Oct 16, 2011 05:43 AM
BeRightBack
Mar 8, 2009 12:29 PM
lukerc45
Dec 13, 2007 11:42 AM
SpoolinMotors
Dec 5, 2006 11:00 AM
digink
Jul 31, 2004 09:42 AM
