"Idle" problem.
Old Feb 15, 2008 | 02:22 PM
phiq's Avatar
Default "Idle" problem.
Hi all. I need a little help. I have a Civic 99 with a B16A engine on it. When the motor is hot and after a few seconds of idle, it starts giving me a little problem. When I hit the gas a little bit and the RPMs hit 1.5, it stops there and won't keep going to higher RPMs, instead it drops to 1.0 and goes up again to 1.5 and down again to 1.0. That's just when I hit the gas just a little bit but when I hit the gas all the way down it will pass 1.5 RPMs and hit the red line without a problem. Now if when I'm idling, before it starts the problem, I hit the gas a little bit and maintain the RPMs at 1.5, then it won't start doing it (stopping at 1.5).
For example, I start the car at home and leave. I stop a the red light and let the car idle. When the light goes green, I put 1st gear and go and when it hits 1.5 RPMs it stops and goes down to 1.0 and up again to 1.5 and back down. It looks like when you start learning how to drive standard that the car shakes forward and backwards like crazy. Again, if I hit the gas all the way down like if I was racing it will pass 1.5 RPMs. What could be causing this problem?
Old Feb 15, 2008 | 02:35 PM
crazyguy's Avatar
Default Re: "Idle" problem. (phiq)
what ecu are u running
Old Feb 15, 2008 | 02:37 PM
z6hatchboy's Avatar
iacv, idle air control valve. Take it off and clean/replace it. Check coolant levels too.
Old Feb 15, 2008 | 02:50 PM
civic89si666's Avatar
Default Re: "Idle" problem. (z6hatchboy)
would coolant levels cause that much of a problem? i have a gsr in my hatch that has an idle problem. It jumps like it was really cammed.
Old Feb 15, 2008 | 02:59 PM
z6hatchboy's Avatar
Default Re: "Idle" problem. (civic89si666)
It can, sometimes bleeding the coolant system will help. But a lot of the time, if its when cold its the fitv if its when motors warm then the iacv.
Old Feb 15, 2008 | 03:04 PM
well, i put an all new iac on it and nothing changed. it fixes itself every now and again. Wat is the fitv? and would mine be caused by the coolant.
To the OP, i didnt mean to jack your thread.
Old Feb 15, 2008 | 03:17 PM
phiq's Avatar
Don't worry.
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
psilo
Nov 11, 2004 06:04 AM
uszcrx
19
Jun 19, 2003 04:27 AM
Boost2NA
Sep 10, 2002 02:33 AM
