Classic Hondas All Pre-1988 Hondas.
77 Civic CVCC Tailights dont work
Old Feb 15, 2008 | 01:33 PM
Repn Ludes's Avatar
Default 77 Civic CVCC Tailights dont work
all the lights work but the brakes lights dont work when the brake is pushed in... all i can think of is the brake switch since all the fuses are good any help....????
Old Feb 17, 2008 | 08:55 AM
78CITYTURBO's Avatar
Default Re: 77 Civic CVCC Tailights dont work (Repn Ludes)
Go here. You can get plenty of help there...
http://www.1stgencivic.com/wor...x.php
Old Feb 20, 2008 | 11:06 PM
XANTHODC2R's Avatar
Default Re: 77 Civic CVCC Tailights dont work (78CITYTURBO)
1st use a tester and test if there is juice going to light bulb socket. I had a problem with my rear brake lights too and discovered that there is some wire i dont know if its the ground wire that needs to be pinched between bulb and socket. I dont know why Honda didnt solder it. Check it out and see what happens.
Old Feb 23, 2008 | 09:48 AM
Repn Ludes's Avatar
Default Re: 77 Civic CVCC Tailights dont work (XANTHODC2R)
so weird.. i took off my light and all the bulbs were fine. i bought a brake switch cause the old one tested bad, tested the new and its working.. idk weird might have to just over the whole car
Skar-ZA
Jun 10, 2013 05:56 AM
WhatASlowEg
Nov 23, 2009 08:49 PM
alpha_1
Suspension & Brakes
Mar 2, 2009 12:53 PM
biggoofy
Dec 29, 2008 12:31 PM
Remixedlatino
Jul 5, 2007 06:15 PM
