77 Civic CVCC Tailights dont work
all the lights work but the brakes lights dont work when the brake is pushed in... all i can think of is the brake switch since all the fuses are good any help....????
Re: 77 Civic CVCC Tailights dont work (Repn Ludes)
Go here. You can get plenty of help there...
http://www.1stgencivic.com/wor...x.php
Re: 77 Civic CVCC Tailights dont work (78CITYTURBO)
1st use a tester and test if there is juice going to light bulb socket. I had a problem with my rear brake lights too and discovered that there is some wire i dont know if its the ground wire that needs to be pinched between bulb and socket. I dont know why Honda didnt solder it. Check it out and see what happens.
Re: 77 Civic CVCC Tailights dont work (XANTHODC2R)
so weird.. i took off my light and all the bulbs were fine. i bought a brake switch cause the old one tested bad, tested the new and its working.. idk weird might have to just over the whole car
Skar-ZA
06-10-2013 05:56 AM
Remixedlatino
07-05-2007 06:15 PM
