integra brace on civic?
Old Feb 15, 2008 | 12:07 PM
sk8shorty012's Avatar
Default integra brace on civic?
Well i've been considering an H-brace type piece for a while now as I have alot of front end slop (also due to broken mounts), but instead of going with a Megan / NRG 4 point bar, which I've heard are kind of shitty in numerous ways, I really would rather stay with the 2pt brace that was put on the integras. Does anyone know / has anyone tried to fit the dc4 front brace (pictured below) on a 96-00 civic? I think with the "EG" civics, it'll probably be fine, I'm just unsure with the "EK" civics.
#5 in the image, 50205-ST7-000
Old Feb 15, 2008 | 02:24 PM
no one has done this?
Old Feb 15, 2008 | 03:48 PM
instrument's Avatar
i have never heard or seen that part and would love to see one.
any real pics?
and i cant see how that would do anything to help your blown mounts.
Old Feb 15, 2008 | 04:49 PM
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i have never heard or seen that part and would love to see one.
any real pics?
and i cant see how that would do anything to help your blown mounts.</TD></TR></TABLE>
I hadn't heard of it either. I don't have any pics at the moment. I tried to google it but came up with nothing. I know that for instance the "beaks" bar fits EG / EK / DC, but im unsure if its the same with this?
I'd be using this bar as alternative to an "H" Brace, not for the blown mounts.
Old Feb 15, 2008 | 05:19 PM
ejoner's Avatar
Default Re: (sk8shorty012)
I have that bar, its a upper cross member brace. Direct fit into eg chassis, don't know about ek's. I don't know if it made a difference because I did all my suspension work at once.
Old Feb 15, 2008 | 05:26 PM
Default Re: (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">I have that bar, its a upper cross member brace. Direct fit into eg chassis, don't know about ek's. I don't know if it made a difference because I did all my suspension work at once.</TD></TR></TABLE>
Good to know. However, I need to find out about ek's. I guess ill just order it and see what happens. Worse comes to worse I would just have to a bit of custom work. It SHOULD make a difference, I just didnt want something like the H brace hanging down low, however I wanted the front end support. Both the ITR / S2000 have them, so I figure it can't hurt, especially when the steering in both cars is nice and tight.
Old Feb 15, 2008 | 05:54 PM
bluelxfodo's Avatar
i seen lots of LS/GSR tegs have this i have it on my LS and on an EG hatch i think i felt more of a difference with an H brace in stead of that. i think its one of those you have it or you dont
Old Feb 15, 2008 | 06:58 PM
Default Re: (bluelxfodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluelxfodo &raquo;</TD></TR><TR><TD CLASS="quote">i seen lots of LS/GSR tegs have this i have it on my LS and on an EG hatch i think i felt more of a difference with an H brace in stead of that. i think its one of those you have it or you dont </TD></TR></TABLE>
Hmm... if I could use an H brace I would. This bar is my alternative but I just would like to know if it'll fit..
Old Feb 15, 2008 | 09:54 PM
1EK1EG's Avatar
I know for a 92-95 civic there are 4 holes in the cross member,2 on each side.I have a x member bar on my hatch,but never looked into it for a ek.Ill check tomorrow if you dont check before I do.
Old Feb 15, 2008 | 10:20 PM
bluelxfodo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm... if I could use an H brace I would. This bar is my alternative but I just would like to know if it'll fit..</TD></TR></TABLE>
it might fit should be 4 holes there too... but then again i never seen/took the time to see if 96-00 civic's had them more than likely if they had them it would be on Si models i would assume.
Old Feb 16, 2008 | 08:35 AM
Default Re: (1EK1EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1EK1EG &raquo;</TD></TR><TR><TD CLASS="quote">I know for a 92-95 civic there are 4 holes in the cross member,2 on each side.I have a x member bar on my hatch,but never looked into it for a ek.Ill check tomorrow if you dont check before I do.</TD></TR></TABLE>
Perfect, I'll busy the next couple of days so if you want to check and let me know that'd be awesome.
it might fit should be 4 holes there too... but then again i never seen/took the time to see if 96-00 civic's had them more than likely if they had them it would be on Si models i would assume.</TD></TR></TABLE>
that's kind of my assumption. I ordered it today so I guess we'll see what happens.
Old Feb 16, 2008 | 09:27 AM
Luserkid's Avatar
I have that bar, it did wonders when i first put it on. Now im meh about it because im used to it Will not fit "EK" because they have different subframes. I recommend the bar
Old Feb 16, 2008 | 09:38 AM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I have that bar, it did wonders when i first put it on. Now im meh about it because im used to it Will not fit "EK" because they have different subframes. I recommend the bar </TD></TR></TABLE>
yeah that's kind of what I figured. I JUST ran out to the service bay and looked under a car and did NOT see the four bolt holes for it to fit into. Hmm, so any recommedations on a lower bar?
Old Feb 16, 2008 | 11:10 AM
bluelxfodo's Avatar
yeah that's kind of what I figured. I JUST ran out to the service bay and looked under a car and did NOT see the four bolt holes for it to fit into. Hmm, so any recommedations on a lower bar? </TD></TR></TABLE>
switch out sub frames!! haha j/k too much work for that small bar. Full race has a Adjustable traction bar
Old Feb 16, 2008 | 11:17 AM
switch out sub frames!! haha j/k too much work for that small bar. Full race has a Adjustable traction bar </TD></TR></TABLE>
yeah, ill probably just try to find a solid front bar, such as the benen one:
http://passwordjdm.com/Benen-I....aspx
Old Feb 16, 2008 | 02:40 PM
bluelxfodo's Avatar
http://passwordjdm.com/Benen-I....aspx</TD></TR></TABLE>
that looks like a good one! there is also a few others out there i seen
Old Feb 16, 2008 | 02:49 PM
that looks like a good one! there is also a few others out there i seen </TD></TR></TABLE>
Yeah, I was just looking at the carbing one. It looks solid and has the name behind it and is less than the benen one at only $75.
GotRiceYo
Sep 4, 2008 05:51 PM
manwezy951
Dec 28, 2007 02:11 PM
simonek87
15
Dec 18, 2007 05:14 PM
K20 EG
Jul 18, 2003 05:58 PM
J2turbo21
15
Apr 17, 2003 04:15 PM
