Vtec-E
Old Feb 15, 2008 | 07:54 AM
eg6freak's Avatar
Default Vtec-E
hey guys! im a noobie to this site.. i had a question about Vtec E.. i know its not a fast motor or anything special.. but is there anyway of keeping this motor that i have and just making it a regular Vtec.. ?? iim not sure if that makes since... but help is greatly appreciated..
thanks!
Old Feb 15, 2008 | 08:02 AM
VTAC-KAT's Avatar
Default Re: Vtec-E (eg6freak)
keep the block and change the head to a regular vtec head
Old Feb 15, 2008 | 08:03 AM
spivt11's Avatar
* B A N N E D *
I'm not sue if you can make it a regular Vtec without doing something major to the ECU, but I do know the Vtec-E was produced to increase efficiency in the lower RPM's which is the opposit of the Vtec basically which optimizes performance in the higher RPM range.
Old Feb 15, 2008 | 08:17 AM
SkoundrelUSA's Avatar
cute little bastard
https://honda-tech.com/zerothread?id=1315461
Old Feb 15, 2008 | 08:20 AM
meandino's Avatar
Get a D16Z6 head and ECU.
Old Feb 15, 2008 | 08:29 AM
Relic1's Avatar
direct answer... no.
a D16Z6 head will result in a 1.5L setup with super low compression, low even for turbo.
the Z1 is a fuel meiser with it's 5-wire O2 and A/Fs that top 17:1 on the highway. Special low volume combustion chaimber in the head and deap dished pistons aided swirl and helped increase mpg figures even more.
the long ratio trans is the largest weakness of the VX, swap in a SI trans if you want notable performance increase.
Other wise put the money you save in fuel into an account and save up for a swap or different car to swap. (a great mpg daily driver is way under estimated)
Old Feb 15, 2008 | 09:09 AM
instrument's Avatar
there's no point to it.
seriously.
get a new motor, or get another car and keep the vx as your commuter.
Old Feb 15, 2008 | 09:19 AM
aznlaoboi315's Avatar
Default Re: (instrument)
vtec-e? is that like when your vtec kicks in to make it up hills??
i have a d16y8 head from a 98' EX if you wanna make it up the hill before vtec engages
Old Feb 15, 2008 | 09:51 AM
smileycvc's Avatar
Default Re: (aznlaoboi315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spivt11 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sue if you can make it a regular Vtec without doing something major to the ECU, but I do know the Vtec-E was produced to increase efficiency in the lower RPM's which is the opposit of the Vtec basically which optimizes performance in the higher RPM range.</TD></TR></TABLE>
That didnt make any sense. Vtec-E is just a 3 stage vtec setup. It increases fuel efficency by only using 8 valves then at a certian RPM all 16 valves open. Then once again at another RPM range regular old vtec kicks in.
Old Feb 15, 2008 | 10:19 AM
Relic1's Avatar
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">That didnt make any sense. Vtec-E is just a 3 stage vtec setup. It increases fuel efficency by only using 8 valves then at a certian RPM all 16 valves open. Then once again at another RPM range regular old vtec kicks in.</TD></TR></TABLE>
sigh... no. it's not. (spivt11 was a lot closer to correct)
the three-stage VTEC mech in the JDM D15b that came in the EG4 and EG8 in japan only. read here if you want to learn more about that... http://asia.vtec.net/article/d15b
(or the link below)
instead of me writing pages about this, here is how VTEC-E works... http://www.b18c5eg.com/VTEC/sohcvtece.html
(note the note at the bottom, I take no credit for that page, I'm only rehosting it because it's great info)
Old Feb 15, 2008 | 10:23 AM
sohctodohc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6freak &raquo;</TD></TR><TR><TD CLASS="quote">hey guys! im a noobie to this site.. i had a question about Vtec E.. i know its not a fast motor or anything special.. but is there anyway of keeping this motor that i have and just making it a regular Vtec.. ?? iim not sure if that makes since... but help is greatly appreciated..
thanks!
dont ruin this motor. and by the way the there isnt a head you can swap on there that is gona net you higher than like 8.5:1 compression so when you decide to swap a mad tyte vtec head on to it, not only will you lose alot of horsepower you still wont be able to hear vtec. so it will b completely pointless. so keep the engine stock and use it for what it was made for MPG!!!!!!!
Old Feb 15, 2008 | 12:42 PM
smileycvc's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
(or the link below)
(note the note at the bottom, I take no credit for that page, I'm only rehosting it because it's great info)</TD></TR></TABLE>
It didnt only come in Japan.
Old Feb 15, 2008 | 12:56 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">It didnt only come in Japan.</TD></TR></TABLE>
true, but us stuck sucking the hind teet in the US never got to see it.
Old Feb 15, 2008 | 02:09 PM
yes you're gonna need all the MPG's you can get, especially with the high gas prices now a days.... If i were you i'd just slap on a new air filter and try to make it up a hil without the vtec turning on. lol j/k
Old Feb 15, 2008 | 03:22 PM
suspendedHatch's Avatar
OMG. Don't listen to anyone in this thread except Relic1. Everyone else's statements are blatantly false.
Except for his recommendation about the Si trans on the D15Z1. Tried that for a short time, and it doesn't work out too well. The Z1 and the P07 ECU are teamed up to run at low low RPM most of the time. The ECU has no way of knowing if you change the gear ratios.
Best thing to do to get a good balance of power/mileage for daily driving with room to grow (and w/out dropping a couple grand) is to swap to a JDM D15B, JDM SOHC ZC, or a D16Z6. Be sure to get a P28 ECU to go with it.
natesfresh
May 16, 2008 12:04 PM
1.3mazda
Feb 27, 2008 07:41 AM
pitoracing24
Oct 27, 2007 01:09 PM
JDMTuner4Life
Feb 24, 2007 07:29 AM
89dxhunchback
Aug 6, 2002 02:37 AM
