ls/vtec ecu advice needed
Old Feb 14, 2008 | 11:14 PM
842177's Avatar
Default ls/vtec ecu advice needed
I'm almost done with my ls/vtec build and am wondering what ECU to use. i have LS block w/p30 pistons and ITR head with cam gears. What are the best ECU options i can go with? Is it okay just to use a P73? Thanks for any advice.
Old Feb 15, 2008 | 02:47 AM
turboZChatch's Avatar
Default Re: ls/vtec ecu advice needed (842177)
A p73 will run the car but your better off running crome or hondata do a search on either and decide what one is better for you
I would suggest the hondata
Old Feb 15, 2008 | 04:42 AM
842177's Avatar
Default Re: ls/vtec ecu advice needed (turboZChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">A p73 will run the car but your better off running crome or hondata do a search on either and decide what one is better for you
I would suggest the hondata</TD></TR></TABLE>
Thanks for info. Any more advice out there? Thanks
Old Feb 15, 2008 | 05:54 AM
mtber's Avatar
A chipped/socketed ecu would be your best bet. For a better understanding, go to http://www.phearable.net/tech/....html for some good reading
lsjon
Mar 18, 2007 08:53 PM
HksHaitian
Sep 10, 2005 08:44 AM
KrispyKreme
Nov 13, 2004 06:56 PM
Mr.DC2TurBo
Sep 15, 2004 12:46 PM
Shane54
Nov 6, 2003 04:26 PM
