SRS service plug part#
I am looking to install a aftermarket steering wheel but I need the part# for the service plug so I can keep my passenger airbag working...I know there are DIY on makeing your own plug however I want to purchase a oem one.....can someone plz help me out with this info>>>>
THanks...
I have a 1997 civic coupe ex in case that matters
THanks...
You need a 2 ohm resistor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">Dougster. Just go out and get/buy a plain 2ohm 5watt resistor. Maybe ratshack will cary it but i don't think so..
First take the plug from the air bag, cut it off. Strip the wires and solder the resistor from one wire to the other. Use some heat shrink tube over the exposed areas. Plug it in and your done. You might need to rest the srs system.
Jump the yellow plug that hooked to your fues box, it's plugged into a dummy connector . And take about three feet of wire so you can use it as a jumper wire.
Close the jumper wire turn the car onto ign (II), SRS light will go off, open the circut. SRS light will come on hold the wires again till the light goes off. It should flash 2 times. Turn the ign all the way off. Wait for 10 seconds. Then tuirn your car on... The light should now be off.
http://www.leedselect.com/parts-resistors.html sells the part for .50cent nugga.
There isn't an OEM one since this plug that you make acts as the airbag under the steering column. What you are thinking is the part to help reset the SRS light by plugging into the plug on the fusebox (which can also be done using a paperclip).
pumpkyn
Jun 1, 2006 11:54 PM
EG93si
Oct 26, 2005 09:52 PM
