GREAT! So i went to go plug in the YEL/GRN Ignition wire and it broke right at the plug
How the hell am I going to fix this? Is there any way I can ghetto rig this? Or find a replacement plug? And did this wire start to be used in 92? BTW 97 Civic with EX motor swap
Re: GREAT! So i went to go plug in the YEL/GRN Ignition wire and it broke right at the plug (pumpkyn
can i find the plug at a junk yard? and will any d-series dist. be fine to pull the plug from?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">just get another plug and get another wire connector and reconnect it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumpkyn »</TD></TR><TR><TD CLASS="quote">can i find the plug at a junk yard? and will any d-series dist. be fine to pull the plug from?</TD></TR></TABLE>
just go to the junkyard find any D series within your Type ( OBDO, OBDI, OBDII)
and cut about 3" of wire off of the plug that way you can just match up the colors to the right pin
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">i go to the junkyards all the time.. Best place to get Misc 10mm bolts and interior screws.. and of course ECU connectors and Engine connectors.</TD></TR></TABLE>
The junkyard i go to rarely has a 92+ Honda and I was lucky enough to show up and find a 92 civic 1 day after it arrived Im pretty sure there are some mroe stuff i should have grabbed off of it but i will see once i get my swap in fully
PSU
25
05-28-2012 07:51 AM
808State
01-06-2005 07:56 PM
