what color oem bearings to use with eagle crank/rods?
Old Feb 14, 2008 | 12:09 PM
surfinjoe911's Avatar
Default what color oem bearings to use with eagle crank/rods?
i am building a block using an eagle lightweight crank and eagle rods. i am trying to figure out what color oem honda bearings i should use with this build. any help is greatly appreciated.
Old Feb 15, 2008 | 07:02 AM
b19coupe's Avatar
Default Re: what color oem bearings to use with eagle crank/rods? (surfinjoe911)
Chances are, you are not going to need just one color bearing. To get nice uniform clearances you normally need multiple colors. If you just want to slap it together and call it a day, you can run all green bearings. <U>I do not recommend this!</U> ( green is the middle of the road bearing)
The proper way to do it is to measure everything and choose the bearings that will give you the clearances that you want.
Try to get #1,#2,#4, and #5 as close as possible to each other. Run #3 a couple of ten thousandths looser.
Old Feb 15, 2008 | 07:25 AM
d15Beta's Avatar
yeah.. if ur going to the extent of using an eagle crank.. u myt aswell take the extra effort in having it precisely measured.. mic it..
and go from there..
GsrIntegra789
Jan 26, 2010 08:21 AM
SlAmMeD 91 HaTcH
Apr 24, 2009 07:48 AM
christion
Dec 22, 2006 06:52 PM
Hoosier Daddy
Nov 9, 2003 01:20 PM
EKweezy
Oct 8, 2003 10:09 AM
