Does Anyone Use Wiseco Pistons Your B18C1 Bored To 84MM?
Go get yourself some bad a$$ rollerwaves:
http://www.theoldone.com/compo....html
The 84 mm b18c pistons are about 1/4 of the way down the page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">The Wiseco B20VTEC pistons are what you are looking for.
Yes, I have used them.</TD></TR></TABLE>That's what I thought. But noooooo...their sale rep disagreed. This is what went on couple hrs ago:
I ask the Wiseco rep. what pistons to use with my B18C1 84mm bored block. His answere:"I don't know" He proceeded to look it up and came back and said "...the biggest size we have is 82mm..". I then said "Since you have pistons that spec for CRV/Vtec that is 84mm rate at 11CR, can I use that?". He then said "It is possible that you can do some sort of modification to make it work"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE »</TD></TR><TR><TD CLASS="quote">The biggest pistons you can use on a B18C with stock sleeves is 82mm.
You'll have to resleeve the block for 84mm pistons.</TD></TR></TABLE>Ofcourse I know that. But my quest is for a sleeved 84mm B18C1 and their catalog and their rep. all agreed that they don't have pistons that meet my need
They are probably unfamiliar with the specifics of B series motors.
Just pick one of the b20/ls vtec piston applications and use a compression calculator.
Youll need the compression height and dome volume.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR »</TD></TR><TR><TD CLASS="quote">That's what I thought. But noooooo...their sale rep disagreed. This is what went on couple hrs ago:
he's probably a noob. can't blame him. give them a call back and try talking to someone with more experience.
</TD></TR></TABLE>he's probably a noob. can't blame him. give them a call back and try talking to someone with more experience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satitus »</TD></TR><TR><TD CLASS="quote">Go get yourself some bad a$$ rollerwaves:
The 84 mm b18c pistons are about 1/4 of the way down the page.</TD></TR></TABLE> bahahahahahahahaha rolerwave is a old v8 thing that has been prouven not to make anymore power don't wast your money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Talk to Jeff at Blueprint MFG., he is a WD for Wiseco and has sold more B-series pistons than most.</TD></TR></TABLE> jeff is a scam artiest was importbuilders and scammed to many people with that name so now he is blueprint with been of v2 both just copy and relabel other peoples hard work and call it there own go to there site they have a ge vtec kit they photo shopped and changed the color and called it there design but when you order one its a golden eagle kit hate scamers like them.
to the op the 84mm wisco pistons will be fine i have built many b18c motors with them no problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by masterbuilder »</TD></TR><TR><TD CLASS="quote"> jeff is a scam artiest </TD></TR></TABLE>
Not true, and irrelevant to this post.
He is a WD for Wiseco and has some knowledge about Wiseco pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Not true, and irrelevant to this post.
He is a WD for Wiseco and has some knowledge about Wiseco pistons.</TD></TR></TABLE> sorry 100% relevant and true he is even banned on ht there are many post about him on here all bad for a reason and his knowledge is only what wisco tells him that he trays to say it the other way around like he designs wisco pistons he is a joke
