mysterious car troubles. iacv related possibly?
Old Feb 14, 2008 | 09:57 AM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default mysterious car troubles. iacv related possibly?
this is going to be a long read so prepare yourself; i want to give you guys every single detail so maybe you guys can tell me WTF is wrong. stupid car... well, one night i was driving and then my car started sputtering and would cut out(decelerate) for 1-2 second then come back again, and it would keep doing this constantly. so my friends and i thought it was the dizzy, so i changed to all new ignitor, coil, and spark plug wires. sweet, it went away. now a month later, it started doing the exact same thing, not knowing what to do, and completely confused.. somebody suggested that it was the iacv and disconnected it and said if it is doing those things(bogging/sputtering) its normal with it disconnected but its not suppose to do that with the iacv connected(supposedly meaning, the iacv is doing its job), but i have use to drive on disconnected iacv and it was fine, just had a low idle and threw a code. but i changed the iacv anyways and it went away, i don't know if i really solved the problem.. this has been a waste of time and money. i never get a cel btw. i'm thinking why would changing the dizzy internals that one night solve the problem when it was the iacv to begin with... help me think, because i'm just completely lost and confused. could it be something on my bbk 70mm tb?
obd2 gsr
Old Feb 14, 2008 | 10:42 AM
Skunk2Brian's Avatar
Default Re: mysterious car troubles. iacv related possibly? (candy eg)
I recommend inspecting your TPS sensor. A sensor that is out of calibration will generate the same kinds of symptoms. Although this does not explain the intermittent occurrence of your problem.
Hmmmmm......
Old Feb 14, 2008 | 10:50 AM
candy eg's Avatar
yeah i did think of it being my tps but that makes no sense how the problem would come and go like this and not just do it all the time.
Old Feb 14, 2008 | 10:59 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (candy eg)
vacuum leak? fast idle valve if it has any.
Old Feb 14, 2008 | 03:46 PM
candy eg's Avatar
if it was a vaccum leak, wouldn't my idle constantly surge? my idle only surges sometimes.
Old Feb 16, 2008 | 11:11 PM
candy eg's Avatar
Old Feb 20, 2008 | 06:05 AM
candy eg's Avatar
bump
Old Feb 20, 2008 | 07:07 AM
alterdcreations's Avatar
weather conditions?
dth0ng69
Oct 8, 2009 12:48 PM
wolfman_dlc
Sep 17, 2008 04:28 PM
Touge Tuning
Dec 18, 2005 12:42 PM
Red00SI
May 10, 2002 01:20 PM
