swap time
I'm about to convert my ej1 to a 5speed. I'm getting a 91 crx hf which has a jdm B16 in it. I know what i need as far as parts; but what exactly can i swap over? What do i need off another civic if anything. As much as i can transfer over i will.
tranny
clutch/fly/pressure plate
starter
clutch resoivor
lines
slave/master cylinder
ecu
pedal assembly
throttle cable
shift linkage
console piece
shift boot/****/shifter
shifter bushings
mounts
I know off top i need the console from a civic and B series mounts. The pedal assembly too? Any help would be appreciated.
tranny
starter
clutch resoivor
lines
ecu
pedal assembly
throttle cable
shift linkage
console piece
shifter bushings
mounts
