Where can i buy a hondata k pro ecu?????HELP!!!
Old Feb 14, 2008 | 07:18 AM
dawn's Avatar
Default Where can i buy a hondata k pro ecu?????HELP!!!
I would like to just buy the ECU with out sending my stock rsx computer does anyone no where i can jus buy a k pro ecu with out sending the core computer?
Old Feb 14, 2008 | 08:58 AM
chad's Avatar
Moderator
Default Re: Where can i buy a hondata k pro ecu?????HELP!!! (dawn)
what year etc si your car?
Old Feb 14, 2008 | 05:30 PM
drhonda's Avatar
any hondata dealer should be able to do it.
Old Feb 14, 2008 | 08:38 PM
toyomatt84's Avatar
Sanji
Do you plan on soldering the chip in yourself? The K-Pro unit is an on-board solder-in chip.
Old Feb 15, 2008 | 07:53 AM
dawn's Avatar
Default Re: (drhonda)
the civic is a 97 and the k20 is out of a 06 rsx type s...i have the computer out of it but when the car was set on fire it destroyed the stock ecu so i would really just like to buy a k pro straight up no reflashing or any of that stuff if its possible.
Old Feb 18, 2008 | 01:01 AM
RS2 FAB's Avatar
Default Re: (dawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawn &raquo;</TD></TR><TR><TD CLASS="quote">the civic is a 97 and the k20 is out of a 06 rsx type s...i have the computer out of it but when the car was set on fire it destroyed the stock ecu so i would really just like to buy a k pro straight up no reflashing or any of that stuff if its possible.</TD></TR></TABLE>
k pro is not a standalone it's actually a modifed honda ecu (thats more than im probably allowed to tell you yes i am afraid of hondata and their past shows they have money to f with people )
so ill try to reveal as little as possible to keep my *** out of a lawsuit.
you need a working legit ecu (02-04 and now 05-06 for a little more) and you need to send it in...........
or you can locate a dealer and they will do it for you in store/shop
the hondata reflash is simply a new ROM uploaded to the ECU (there is soooo much more info i want to tell you about this but nobody wants to get in trouble!)
Old Feb 18, 2008 | 06:38 AM
dawn's Avatar
Default Re: (RS2 FAB)
i completely understand...but could you do me one favour and just tell me if it is a bad idea to get a k pro and if there is a better choice available???
Old Feb 18, 2008 | 02:33 PM
ekb16's Avatar
i believe you can buy the kpro from k20tuned.com...might be around $1200-1300
Old Feb 18, 2008 | 06:17 PM
dawn's Avatar
Default Re: (ekb16)
thanks alot ill check it out man...i appreciate it!!
Old Feb 18, 2008 | 06:51 PM
RS2 FAB's Avatar
Default Re: (dawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawn &raquo;</TD></TR><TR><TD CLASS="quote">i completely understand...but could you do me one favour and just tell me if it is a bad idea to get a k pro and if there is a better choice available???</TD></TR></TABLE>
there is nohing comparable.............. but the AEM EMS is right there in the price range with a greater control of everything, only downfall = more work to get the standalone wired in it's not plug and play like hondata
Old Feb 18, 2008 | 07:22 PM
dawn's Avatar
ok...I've come across a problem in my research with the hondata kpro...i heard that the vss sensor in the 05-06tranny is different from that in the 02-04tranny and the hondata kpro does not read the vss sensor in the 05-06tranny so i was told my best bet is to buy a 02-04 type s tranny to use with my 05-06 motor and ill be good to go...have you ever heard about this problem and is there any easy way around it other than wiring the car myself?
Old Feb 18, 2008 | 07:28 PM
RS2 FAB's Avatar
Default Re: (dawn)
no you're correct, that 05-06 thing i mentioned was for the rsx dudes.
scroll down to the bottom
http://www.hondata.com/kpro.html
Modified by RS2 FAB at 8:43 PM 2/18/2008
Old Feb 18, 2008 | 07:36 PM
dawn's Avatar
ok...i found a place that sells the k pro ecu (k20tuned.com the guy a few posts back gave me the site thanks alot!!) so in order for that to work with my 05-06 tranny i just need to add on an adapter harness to my list of parts? am i correct or am i confusing myself?
Old Feb 18, 2008 | 07:41 PM
dawn's Avatar
i understand that im going to have to buy an 02-04 rsx ecu and send it to hondata...and it seems thats the only way i can do it correct? becuase if i buy the k pro from this site im sure the 02-04 ecu wouldnt come with the adapter to work on the 05 06 tranny?
Old Feb 18, 2008 | 07:44 PM
RS2 FAB's Avatar
Default Re: (dawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawn &raquo;</TD></TR><TR><TD CLASS="quote">i understand that im going to have to buy an 02-04 rsx ecu and send it to hondata...and it seems thats the only way i can do it correct? becuase if i buy the k pro from this site im sure the 02-04 ecu wouldnt come with the adapter to work on the 05 06 tranny?</TD></TR></TABLE>
you can buy k-pro with a supplied 02-04 prb ecu from them, i think its like 300 more it says on their website it is offered as package 2 or w/e
Old Feb 19, 2008 | 03:29 PM
v4lu3s's Avatar
RTFM
have you tried ebay.com before? its a pretty neat place to find stuff, and sometimes the prices are great!
Old Feb 20, 2008 | 12:25 PM
dawn's Avatar
ok i see the product your talking about now, will that be able to work with the 96-00 civic chassis (EK)
Old Feb 21, 2008 | 08:38 AM
Spunkster's Avatar
You should only buy from the delaers listed at http://www.hondata.com/dealers.html
Buying from anyone else you are taking a risk as they are not an authorized dealer. Buying from ebay is even worse as you may end up buying a damaged ecu. Hondata does not allow it's dealers to sell on ebay.
Old Feb 21, 2008 | 09:01 AM
dawn's Avatar
Default thanks!
well thanks everyone for your help guess i cant get around the fact that i have to swap the tranny casing to get everything to work...im still curious to no though, im swapping the dash to the rsx dash are me speedo and tach n everything still goin to work if i use the k pro???
Old Feb 21, 2008 | 09:14 AM
ekb16's Avatar
try searching around on k20a.org..that forum is dedicated to K series only
Old Feb 21, 2008 | 01:00 PM
RS2 FAB's Avatar
Default Re: thanks! (dawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawn &raquo;</TD></TR><TR><TD CLASS="quote">well thanks everyone for your help guess i cant get around the fact that i have to swap the tranny casing to get everything to work...im still curious to no though, im swapping the dash to the rsx dash are me speedo and tach n everything still goin to work if i use the k pro???</TD></TR></TABLE>
alright you seem to be a little confused. you don't have to swap trans casses, just have to mess with the speedo in the trans casing.
the rsx dash isn't a great fit it'll fit but w/e you're speedo/tach still operates with the conversion harness.
YOU DO NOT REWIRE THE ENTIRE CAR WHEN YOU DO A K SWAP EVERYBODY THINKS YOU DO BECUASE THEY SEE THE HARNESS FOR SALE
THE HARNESSE IS A PLUG AND PLAY EINGINE BAY HARNESS, IT PLUGS INTO BOTH SIDES OF THE INTERIOR BAY HARNESS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the swap is easier than you're making it man. i seriously suggest you slow down and read the actual instruction manuals that came with the parts you bought!
if you don't have it download hybrid racing's mount kit install guides, and download k-pro's install guide then go download either hybrid racings PNP harness install then read them ALL three times THEN come back here and ask your questions.
it's almost easier for me to just run over there and do your swap for you! (it's hard to explain man, plus i finished my swap 6+ months ago so it's hard to rember this ****)
Old Feb 21, 2008 | 03:53 PM
dawn's Avatar
Default Re: thanks! (RS2 FAB)
well if thas how u feel gimme a price man...wont be as easy as u think over here though cuz 99% percent of the things u will need i would have to fly in...the is a small island man wit nuttin on it so gimme a price
SaraGonyea
May 30, 2018 10:21 PM
01_CivicEM2
Honda Civic (2001 - 2005)
Sep 12, 2011 11:23 AM
KidFrost
Feb 15, 2010 10:14 PM
23psi4age
Nov 18, 2002 01:32 PM
