Wheel Problem
Old Feb 13, 2008 | 05:19 PM
Khmerican's Avatar
Default Wheel Problem
Hello, i purchased a set of bbs wheels a while back and it turns out the lug pattern does not match my car. I was given false information about the pattern when i bought it so I guess im stuck with the wheels. My question is, how can i find out what lug pattern my wheels are. The wheels are deffinitely not 4x100 or 4x114.3. Also, I dont have time to match up every different 4 lug to see if it fits. I would try to resell them if i knew the lug pattern of them, but if possible i would like to make it work on my ek hatch. I have heard of people redrilling into the wheels and also the hubs. The wheels themselves have little areas that look like they would accomodate that. If i were to do so, where would i go to get that done and how much would it cost? Also, another option would be to use wheel spacers, but they are a little too pricey for me, and also my wheels have a low offset as it is, i wouldnt want them to stick past my fenders. Any good advice would be greatly appreciated! Here is a picture of my one wheel i had been working on.
Old Feb 13, 2008 | 05:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel Problem (Khmerican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khmerican &raquo;</TD></TR><TR><TD CLASS="quote">how can i find out what lug pattern my wheels are.</TD></TR></TABLE>
Sickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
You'll find the answer there. Scroll down to the "Wheels FAQ" and look for the question, "What is bolt pattern (lug pattern)?"
I do NOT recommend drilling your wheels for a different lug pattern, which will make them weaker. Just re-sell them (or, if you can, return them for a refund), and buy wheels with the lug pattern that matches your car.
Old Feb 13, 2008 | 10:40 PM
r.wright's Avatar
measure them first then resell them on ebay..i will take a wild guess and say they are either 4x108( old fords) or 4x98 (fiats)
check this out:
Old Feb 14, 2008 | 05:46 AM
Khmerican's Avatar
Default Re: Wheel Problem (Opossum Jenkins)
Thanks for the great advice guys! When i measure it with my crappy ruler it seems to be at around 11 or 12 mm, i cant really get an accurate reading. So I assume its 4x112, if thats even a lug pattern.
Old Feb 14, 2008 | 06:54 AM
qhondak's Avatar
Me, personally, think there's nothing wrong with redrilling the wheels. There are a lot of wheels out there with a 4x100 lug pattern and a a different 4 lug pattern. As long as its still 4 lugs, it should be fine, but thats just my opinion. Now if the wheels were 5 lug and you wanted to drill for 4 lugs, there could be a problem.
Old Feb 14, 2008 | 04:37 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khmerican &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the great advice guys! When i measure it with my crappy ruler it seems to be at around 11 or 12 mm, i cant really get an accurate reading. So I assume its 4x112, if thats even a lug pattern.</TD></TR></TABLE>seems you are measuring wrong... for example: 4 inches hole to hole diagonally would be a 4x100 rim (100mm = about 4 inches)
Old Feb 14, 2008 | 04:52 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">seems you are measuring wrong... for example: 4 inches hole to hole diagonally would be a 4x100 rim (100mm = about 4 inches)</TD></TR></TABLE>
I assume he meant that he couldn't get an accurate reading, it looks like 11 or 12 cm (110 or 120 mm) but he can't get more accurate than that...
Old Feb 15, 2008 | 11:28 AM
<StevieG>'s Avatar
there 4x108 and i have two that i bought, then i bought converters for the 4x100 to 4x114 and they didnt work lol
Old Feb 15, 2008 | 10:03 PM
Khmerican's Avatar
Default Re: (03civicdopejmd)
AWESOME!!!! Thank you 03civicdopejmd! That helped me out a bunch!
Old Feb 15, 2008 | 10:43 PM
<StevieG>'s Avatar
lol i would love to sell these lol but we have this problem cause our honda brand doesnt have 4x108
Old Feb 15, 2008 | 10:55 PM
Khmerican's Avatar
Haha yeah, i dont think it will that easy to sell. I noticed you posted on vwvortex also, any luck?
Old Feb 15, 2008 | 11:03 PM
<StevieG>'s Avatar
tonight i actually found a guy on there selling something that imma buy cause just, wow.......i went on there and went nutslol
Old May 13, 2008 | 08:19 PM
Khmerican's Avatar
Sorry for bringing this up from the dead, but i had my wheels redrilled and they are a very viable option. It cost me 140 dollars total to do all four wheels. All the guy did was widen up the hole alittle with a special cad redrilling machine. He then hammered in metal ring that would support the studs. I am bringing this back because i remember i had trouble with options and lack of info on what to do with my wheels. Hopefully this will help someone else out.
Old May 13, 2008 | 09:07 PM
r.wright's Avatar
Default Re: (Khmerican)
what is he doing w/ that plunger haha..jk.... rolling the fender lips lol
so the rims were 4x108 right and he inserted them to 4x100?
Old May 13, 2008 | 09:51 PM
evil_ryu's Avatar
oh man u got gank'd...
Old May 13, 2008 | 10:07 PM
dipsy's Avatar
Hookers and blow
wow theres a wheel forum....this place is boring back to GDD....high ralph :waves like richard simmons:
Old May 14, 2008 | 03:25 PM
Khmerican's Avatar
Default Re: (Opossum Jenkins)
Haha, yes that sir is a plunger and it isnt the best method to roll the rear, as it is pretty stiff. I just took a big hammer to it later. The man i took my wheels to get done was surprised i found out about him because he usually gets calls from dealerships( i googled him and his name popped up with a number). I guess this process is common among dealerships( atleast in my area).
iHEARTMYCiViC
May 6, 2012 11:29 AM
blackhope121
May 9, 2007 12:35 PM
JunIntegra
Oct 12, 2003 07:25 PM
stumpyf4
Nov 21, 2002 11:33 PM
f22bToSlow
Oct 23, 2002 11:25 AM
