Snapped VALVE COVER BOLT
Very carefully with a tap set. Ive had to do it twice. first time I was successful, second time not so much
ended up ruining the threads for it
Before that, if possible, it's time for the WD-40 and vise grips. If there's even just a little piece sticking out you should be able to grab it and carefully remove it. Just soak it good and wait first. Worked for me once.
no you don't need the tap set...just unscrew the borken bolt out of the head. simple as that...just go to a junk yard and pull another valve cover bolt out of another civic. just use a wrench to get that broken piece out...gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">take the valve cover off and use a deep socket to remove the broken bolt. i cant remember it is 10mm or 12mm</TD></TR></TABLE>
i think he has a single cam and if he does its a whole bolt that threads into the cam cap
00ekcoupe
37
Sep 5, 2005 06:15 PM
