Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Reverse Grind
Old Feb 13, 2008 | 07:40 AM
FlatlineSI28's Avatar
Default Reverse Grind
Every now and then.. mainly when the car is cold.. I push down the clutch to the floor and go to put it in reverse and it makes a clanking sound. Does neone else have a similar problem?
I have an 07' Si Sedan
Old Feb 13, 2008 | 07:43 AM
siboii08's Avatar
Default Re: Reverse Grind (FlatlineSI28)
Do you mean the whinding noise it makes when you reverse? Or the click noise it makes when you put it into gear?
Old Feb 13, 2008 | 07:57 AM
Default Re: Reverse Grind (siboii08)
Nah its not the winding in reverse
I know the click noise is normal but its making a short grinding noise... My clutch feels like its okay. I really havent beaten on it. There is also 13,000 miles on the car and i havent changed me tranny fluid. That will be happening tomorow. Maybe that could be an issue. but its makes that noise just as often as my third gear issue that everyone has.
Old Feb 13, 2008 | 08:00 AM
IT GUY's Avatar
Have you tried putting the car in 6th (4th for a 5spd) before reverse? That's always been a "trick" with Hondas. I think it may even mention it in the owner's manual.
Old Feb 13, 2008 | 08:05 AM
Default Re: Reverse Grind (IT GUY)
no but i will have to test tha tone out. Sounds weird haha but ill try it.. I hope that is solves the issue. Thanks
Old Feb 13, 2008 | 08:11 AM
siboii08's Avatar
Good luck pal. Post up the results.
Old Feb 13, 2008 | 08:16 AM
sure thing.. thanks for all of your info. I aprreciate it. I'll let you know
Old Feb 13, 2008 | 10:25 AM
chiggin's Avatar
I have heard the reverse grind before on my 07 Si as well. The only times I have heard it is when I go to reverse after coming to a stop from moving forward. I usually put it in 1st before going to reverse, then there is no grind. I guess putting it in 6th would do the same thing.
Old Feb 13, 2008 | 10:48 AM
hondamanforlife's Avatar
in the past 1st gear is the same as reverse. puting the shifter in 1st lines the sycro's up for a smoth trans to reverse. not sure about our 6 speeds. but yes sometimes I have trouble with R
Old Feb 13, 2008 | 01:14 PM
zid's Avatar
zid
Default Re: Reverse Grind (hondamanforlife)
also make sure the car is absolutely still. if youre rolling at all itll grind.
Old Feb 13, 2008 | 01:51 PM
Bulli Kid's Avatar
Default Re: Reverse Grind (zid)
Press the clutch in And wait for about 2 seconds before goign into gear. REverse has no syncro and has to self align,m therefore it takes longer.
Old Feb 14, 2008 | 07:45 PM
Default Re: Reverse Grind (Bulli Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid &raquo;</TD></TR><TR><TD CLASS="quote">Press the clutch in And wait for about 2 seconds before goign into gear. REverse has no syncro and has to self align,m therefore it takes longer. </TD></TR></TABLE>
yeah thats what my father thought... how often should i change my tranny fluid?
Old Feb 14, 2008 | 08:59 PM
elohel's Avatar
Are you rolling forward at all? Even the slightest movement forward will cause a grind? Only asking because I seem to have every single tranny problem found on the SI in my tranny, but no reverse grind.
Old Feb 14, 2008 | 10:01 PM
Default Re: Reverse Grind (elohel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">Are you rolling forward at all? Even the slightest movement forward will cause a grind? Only asking because I seem to have every single tranny problem found on the SI in my tranny, but no reverse grind.</TD></TR></TABLE>
no im not moving forward at all.. i think maybe thats my issue.. ill have it parked in my driveway on a hill... put my foot on the brake.. release hand brake.. clutch to floor.. and it grinds going in sometimes... it doesn't really grind to much.. its more like a clanking noise
Old Feb 14, 2008 | 10:09 PM
elohel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatlineSI28 &raquo;</TD></TR><TR><TD CLASS="quote">
no im not moving forward at all.. i think maybe thats my issue.. ill have it parked in my driveway on a hill... put my foot on the brake.. release hand brake.. clutch to floor.. and it grinds going in sometimes... it doesn't really grind to much.. its more like a clanking noise </TD></TR></TABLE>
I gotcha. I get a clunk as well sometimes
Old Feb 14, 2008 | 11:34 PM
C Squared's Avatar
Been driving Hondas for 10 years. I now instinctively check into first and then go into reverse when backing up. Weird I know, but always works for me.
Old Feb 15, 2008 | 03:54 PM
yeah.. im getting that instinct to go to fifth ad now reverse.. but idk.. i feel liek these tranmissions suck.. but at least now fox is battling with the third gear issue https://honda-tech.com/zerothread/2223645 .. hopefully this falls through
Old Feb 15, 2008 | 06:35 PM
TRAG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zid &raquo;</TD></TR><TR><TD CLASS="quote">also make sure the car is absolutely still. if youre rolling at all itll grind.</TD></TR></TABLE>
thats what i was coming here to say (x2)
Old Feb 17, 2008 | 09:18 AM
yeah im not movign at a.. i make sure haha
Old Feb 17, 2008 | 09:45 AM
teggy2154's Avatar
Default Re: (FlatlineSI28)
i got the same problem in the mornings. I just put mine in 2nd real quick then put it in reverse.
corcoran_chris
Dec 11, 2008 10:07 AM
vipersvenom
Jun 18, 2008 10:21 AM
