i spun out the other night what do you guys think
Old Feb 13, 2008 | 06:02 AM
93egboosted's Avatar
Default i spun out the other night what do you guys think
the other night i was driving down the road and my car started fish tailing back and forth and i tried counter steering and i just couldnt save it and i hoped a curb. Now my car seems to go strait down the road but the steering wheel is turned to the left?? Do you guys think that it just needs an alighment or do you think that i might of bent something?
thanks
john
Old Feb 13, 2008 | 06:08 AM
dohcVTECeg2's Avatar
Default Re: i spun out the other night what do you guys think (93egboosted)
i think you should get it checked
i cant guess anything without even looking at it. look for yourself and youll find out what need to be done next. then maybe you could have saved me the time of actually reading your thread
Old Feb 13, 2008 | 06:17 AM
Default Re: i spun out the other night what do you guys think (dohcVTECeg2)
i wanted to see if anyone could give me an idea of what could be wrong. i would think maybe something with the steering rack because the wheels see pretty straight but the steering wheel isnt staight with the tires. yea your right i need to look at it to get a better idea i just hope i didnt screw it up to bad
john
Old Feb 13, 2008 | 06:49 AM
97Ej6mike's Avatar
Prob just needs an alignment. How about your wheels/rims? Are they at all affected or damaged?
Old Feb 13, 2008 | 07:16 AM
Default Re: (97Ej6mike)
no i dont belive so i got a flat tire but its wasnet flat until the next day
john
Old Feb 13, 2008 | 09:08 AM
blk92_d16's Avatar
First check the components down there for fractures or cracks and replace as needed. Then get a new tire. Then get an alignment.
Hopefully no major damage was done.
Old Feb 13, 2008 | 09:14 AM
DCSportEJ1Civic's Avatar
Default Re: (blk92_d16)
sounds like something could be bent. cars dont really get "knocked" out of alignment. its an adjustment that requires wrenches. id get under it and look for bent parts, or take it to have it checked. it is possible that it just needs aligned, but given that fact that the car hit a curb, i find highly unlikely.
Old Feb 13, 2008 | 09:29 AM
EKSedAndy's Avatar
Default Re: (93egboosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egboosted &raquo;</TD></TR><TR><TD CLASS="quote">no i dont belive so i got a flat tire but its wasnet flat until the next day
john</TD></TR></TABLE>
If the tire went flat slowly over night then you most likely bent the rim and it's leaking around it. Blow the tire up and squirt some dish soap all around where the tire meets the rim, if you see bubbles you know it's bent.
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Get a new tire. Check the rim for cracks. Go to an alignment shop or chassis shop or likewise. Have then inspect your suspension components. If something is bent or broken, it will need to be replaced. Best case scenario is that you get away with just getting an alignment.
You will have to get an alignment whether something is bent or not. If they replace a suspension component after an accident, it needs to be aligned.
It may or may not be your steering rack. If one front wheel goes out of alignment, the steering system will "split" the difference to make the car go straight. The steering wheel angle will be off as a result of the difference in angle.
Drive safely.
Old Feb 13, 2008 | 10:05 AM
Default Re: (B serious)
i not worried about the rim i had a spare rim and tire at my house that is the same wheel and tire size as the other one. im going to put it in my garage prolly tonight and take the wheels off and check it out. hopefully its nothing big. i hope it will be a cntrol arm or somthing
thanks alot for the input
john
Old Feb 13, 2008 | 10:39 AM
steppinrazor19380's Avatar
make sure you check your inner tie rods, hopefully u didnt f up your ca or strut
Old Feb 13, 2008 | 11:47 AM
Alex_G's Avatar
Occupy GDD
Default Re: (steppinrazor19380)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steppinrazor19380 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you check your inner tie rods, hopefully u didnt f up your ca or strut</TD></TR></TABLE>
Thats exactly what I would do too. How fast were you going? If you hit a curb you more than likely did some damage somwhere....
Old Feb 14, 2008 | 02:52 PM
Default Re: (Alex_G)
im not really sure on how fast i was going id have to say atleast 45 but i fishtailed back nd forth like 3 times so i would assume that would slow me down a little bit. it sucks im parronoid about it i havent had time to look at it yesertday was shity out nd tonight i gotta go out to eat with the old lady for valentines day so hopefully 2marro. yea i hope its a tie rod or a control arm. Accualty would ek front end parts work on my eg? control arms? tie rods?
Old Feb 14, 2008 | 03:18 PM
95vxtealhatch's Avatar
FWD cars don't fishtail going down the road while driving straight.
Old Feb 14, 2008 | 03:34 PM
Malakai's Avatar
Default Re: i spun out the other night what do you guys think (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch &raquo;</TD></TR><TR><TD CLASS="quote">FWD cars don't fishtail going down the road while driving straight.</TD></TR></TABLE>
Tru that. Had to be doing something else. Even while taking a hard corner I havent had it fishtail on me.
Old Feb 14, 2008 | 04:05 PM
n8dizzel's Avatar
Really get under that **** and check EVERYTHING! Everything that could have possibly been affected by the hit or for that matter could have caused you to lose control considering you were not doing anything to cause yourself to lose control.
Old Feb 14, 2008 | 04:10 PM
meandino's Avatar
Default Re: i spun out the other night what do you guys think (n8dizzel)
Maybe your steering rack is all messed up. Take it to the shop or something.
Old Feb 14, 2008 | 05:57 PM
Default Re: i spun out the other night what do you guys think (meandino)
i came around a turn and the rode striaghens out and it was a down hill and all i remeber is the *** end sliding out back and forth like three times and then i went off the rode and hoped a curb but wutever its over with now. my question is can i used civic ek front end parts on my eg my buddy has a 4dr ek parts car?
thank you guys for the imput its much appriecated
john
jfish360
Nov 17, 2007 10:39 PM
tom_zeke
14
Mar 20, 2006 08:16 PM
js2k01
Honda S2000
10
Aug 13, 2005 01:36 PM
panda
Jun 28, 2003 11:25 AM
RudeLude
Apr 7, 2003 07:46 AM
