Can i do a rear disk conversion with the DA setup on my EG?
Can i do a rear disk conversion with the DA disks and trailing arms on my EG???????????????????????????????????
i believe that you can, but you have to retain your eg trailing arms. in order to get the drum spinbles off, you'll need to use a propane torch because there is lock tight on it from the fastory. you don't need to get it red hot, but hot enough to burn the loc-tight off.
why does everyone say I BELIEVE YOU CAN and I THINK SO can someone give me a straight answer that knows for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Yes. DA trailing arms use a larger bushing, thats all.</TD></TR></TABLE>
Soichiro-son
16
Mar 29, 2006 09:03 AM
Jawad.
Mar 22, 2003 08:28 AM
