02 turbo rsx type s trouble
Old Feb 12, 2008 | 03:56 PM
typesnick's Avatar
Default 02 turbo rsx type s trouble
does any one make or sell replacement turbos for the rsx type s 02 to 04 greddy kit the type is T517Z. a coupling on the intercooler broke and had a major boost leak and after lemping the car home the turbo was blowing oil out the exhaust side. i rebuilt the turbo and put it back on but it seemed to blow a lot of oil but started to slow down but due to needing my car back i had to pull it all off so i could drive my car. does anyone know if the turbo is used a little more the seals will set and wont leak anymore or do i just need to replace the turbo?
Old Feb 13, 2008 | 12:48 PM
Ironraven's Avatar
Default Re: 02 turbo rsx type s trouble (typesnick)
Are you running stock Greddy oil lines? If so you need to tap the pan and properly run that oil return, otherwise you will just be blowing the seals all over again.
Old Feb 13, 2008 | 04:36 PM
TheShodan's Avatar
Moderator
Default Re: 02 turbo rsx type s trouble (Ironraven)
If the coupler blew while being on the dyno or a high speed run, he easily could have shifted the shaft to where it could have damaged the seals. I've seen this done before
Old Feb 13, 2008 | 05:04 PM
Tippyman's Avatar
Default Re: 02 turbo rsx type s trouble (TheShodan)
Sounds like an overspooled turbo to me...
Old Feb 14, 2008 | 02:22 PM
Ironraven's Avatar
He said he had it rebuilt since but it was still blowing oil past the seals...
EKris
Jul 22, 2008 02:09 PM
randomae
Dec 28, 2006 04:21 AM
nicktagz
Sep 10, 2006 07:38 PM
CRX T-Si
Dec 17, 2004 04:41 AM
93dx--hatch
Jun 23, 2004 08:21 PM
