info on t04b turbo
Old Jul 3, 2002 | 08:13 PM
hybrid94civ's Avatar
Default info on t04b turbo
I want to get a turbo for my gsr it is fully built but I have a friend with a turbonetics t04b turbo he said he will sell to me. Does anyone know any information on the turbo.
Old Jul 3, 2002 | 08:14 PM
DragII's Avatar
25 Year Member
Default Re: info on t04b turbo (hybrid94civ)
is it a straight T4, or is it a T3/T4 hybrid?
a T4 is a little on the big side, but it will still be streetable....expect longer spool times though
Old Jul 3, 2002 | 08:24 PM
Default Re: info on t04b turbo (DragIIDigital)
it is a straight t04. I was also told to run 9.8:1comp. to make up for the lag.Is that true?
Old Jul 3, 2002 | 08:28 PM
BW's Avatar
BW
umm thats so u don't blow up using 93 gas. when u are providing boost either by supercharging or turbo, u are effectively increasing the cr which will provide more power. u need more air, better internals, and run higher gas pressures w/ higher octanes because of this. if i am correct lower compression will hurt the spool because ur not burning the gas more completely and therefore less heat and gas pressure, which in turn means slower spool. winded after that one
[Modified by wrine420, 5:29 AM 7/4/2002]
[Modified by wrine420, 5:32 AM 7/4/2002]
EJ8Squad919
Jun 6, 2012 07:31 PM
nateg
Jan 30, 2007 04:05 PM
bjizzle07
Honda Civic (2006 - 2015)
25
Jan 10, 2007 05:22 PM
wade
Sep 15, 2004 03:20 PM
DaveF
Jul 5, 2004 08:34 AM
