Slugish???? HELP ASAP!!!!
Old Feb 12, 2008 | 01:07 AM
SH's Avatar
SH
Default Sluggish???? HELP ASAP!!!!
Ok.... to start of I have a 93 hatch with a 99 EX Y8 intsalled.
- p28 vergin ECU
- NO ECU codes ( Worked them all out)
- Dizzy that came with the stock B8 CX
-PROBLEM the car is slugish when about to take off, but is fine afterwords after first gear.... ????
- Could it be that the gas is so old???? car has been siting about 6 months?
Any help would be great guys
Old Feb 12, 2008 | 11:04 AM
blk92_d16's Avatar
Bad gas could be the issue, but I believe reading about their being a tooth or 5 degree difference between the B8/Z6/Z1/etc versus the Y8/Y7/etc.
Old Feb 12, 2008 | 11:17 AM
.I.Need.Money.'s Avatar
Default Re: Sluggish???? HELP ASAP!!!! (SH)
Probably just bad gas. It has been sitting for a while.
Old Feb 14, 2008 | 03:21 AM
SH's Avatar
SH
Default Re: Sluggish???? HELP ASAP!!!! (93EGB18C1)
Well I put new gas in the car to see if that was the problem... I let it sit runnung 1 hr and some change. I drove it up and down my drive way, but still that sluggish to it. Also I red lined it to see and to my surprised it replined at 5800-6000 rpm. Which I know it should hit 7000rpm. I'm thinking that the Dizzy that I have on there is the wrong one ( Im using the D15B8 8 valve Dizzy) which im running on a 16 valve could this be the problem. Could I just need a Z6 Dizzy and be done with it?
Old Feb 14, 2008 | 08:38 PM
SH's Avatar
SH
TTT
Old Feb 15, 2008 | 06:57 AM
gourley's Avatar
Your going to need to run a y8 dizzy. When I had the same problem. Put a y8 dizzy on there cut the plug off and wire in the plug off the dizzy you have on the motor. The colors will match right up. Then when you finish that set your timing, new plugs, wires, and a cap and rotor if you buy the dizzy used. Goodluck
Old Feb 15, 2008 | 06:22 PM
SH's Avatar
SH
Default Re: Sluggish???? HELP ASAP!!!! (gourley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gourley &raquo;</TD></TR><TR><TD CLASS="quote">Your going to need to run a y8 dizzy. When I had the same problem. Put a y8 dizzy on there cut the plug off and wire in the plug off the dizzy you have on the motor. The colors will match right up. Then when you finish that set your timing, new plugs, wires, and a cap and rotor if you buy the dizzy used. Goodluck</TD></TR></TABLE>
Why not just buy a used Z6 dizzy saves time... also what you mean set my timing?
Old Feb 15, 2008 | 06:24 PM
gourley's Avatar
d16z6 dizzy is different mounting holes then then d16y8 and you still wont have the right timing. Just buy the d16y8 dizzy.
Old Feb 15, 2008 | 06:30 PM
SH's Avatar
SH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gourley &raquo;</TD></TR><TR><TD CLASS="quote">d16z6 dizzy is different mounting holes then then d16y8 and you still wont have the right timing. Just buy the d16y8 dizzy. </TD></TR></TABLE>
I do have a y8 dizzy just need a bit more info of how to convert it... do you have pictures of how you did yours?
Old Feb 15, 2008 | 06:52 PM
civicb16eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH &raquo;</TD></TR><TR><TD CLASS="quote">
I do have a y8 dizzy just need a bit more info of how to convert it... do you have pictures of how you did yours?</TD></TR></TABLE>
im having the same problem...would like to see how u convert it also..
Old Feb 15, 2008 | 07:29 PM
gourley's Avatar
Default Re: Sluggish???? HELP ASAP!!!! (civicb16eg)
Just cut the plug off the y8 dizzy, cut the plug off the b8, then swap the plug onto the y8 and match the wires up
Old Feb 15, 2008 | 08:30 PM
SH's Avatar
SH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gourley &raquo;</TD></TR><TR><TD CLASS="quote">Just cut the plug off the y8 dizzy, cut the plug off the b8, then swap the plug onto the y8 and match the wires up</TD></TR></TABLE>
Hmmm that doesnt make sence bc my y8 plug fits in the cx harness... why would I just change plugs it would be the same thing need pictures!
Old Feb 15, 2008 | 08:31 PM
93egSLEEPER's Avatar
Hmmm that doesnt make sence bc my y8 plug fits in the cx harness... why would I just change plugs it would be the same thing need pictures!</TD></TR></TABLE>
THE PLUGS ARE DFFERENT!!!! why do you need pics?
Old Feb 15, 2008 | 08:38 PM
SH's Avatar
SH
Default Re: Sluggish???? HELP ASAP!!!! (93egSLEEPER)
I know the plugs are different I need to know if the z6 dizzy will work bc im buying one tomorrow... I heard it will work but with modifications..... if so can I just use another OBD1 dizzy and call it a day for example a DX or LX dizzy?
Old Feb 15, 2008 | 10:20 PM
tofast2belast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH &raquo;</TD></TR><TR><TD CLASS="quote">Well I put new gas in the car to see if that was the problem... I let it sit runnung 1 hr and some change. I drove it up and down my drive way, but still that sluggish to it. Also I red lined it to see and to my surprised it replined at 5800-6000 rpm. Which I know it should hit 7000rpm. I'm thinking that the Dizzy that I have on there is the wrong one ( Im using the D15B8 8 valve Dizzy) which im running on a 16 valve could this be the problem. Could I just need a Z6 Dizzy and be done with it?</TD></TR></TABLE>
when u say u let it sit running for about an hr, that was idling right? if so thats dumb. the engine is not designed to idle for that long, u start fouling plugs up and idling for so long will wear the internals a bit. i have seen it happen so its not good.
you need the dizzy from a z6/y8 and re wire to fit ur cx harness. or buy the conversion harness for the dizzy plugs.
Old Feb 15, 2008 | 10:31 PM
SH's Avatar
SH
Default Re: Sluggish???? HELP ASAP!!!! (tofast2belast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofast2belast &raquo;</TD></TR><TR><TD CLASS="quote">
you need the dizzy from a z6/y8 and re wire to fit ur cx harness. or buy the conversion harness for the dizzy plugs. </TD></TR></TABLE>
I must say letting it sit there is not dumb at all... one hour would not have hurt it. The car it self has been at rest for 6 months and letting it run a while its a pretty damn good idea. Your andswer to ur question yes it idles just fine, but when you try to take off sluggish then picks up.
Old Feb 15, 2008 | 11:31 PM
RunninEg6's Avatar
i got the same problem. except i have a d15b7 and i replaced the dizzy few weeks ago brand new. now it runs slow as hell. almost like the dizzy is turned all the way retarded except it's advanced. and once in a while after driving on the highway my air/fuel ratio leans out and throws a code 43, fuel supply system. changed plugs, wires, fuel filter, and injector cleaner in the tank. fuel pump is good. no fuel leaks or crushed lines. same thing still happening. only thing i need to try is to see if the o2 sensor is goin out and change it and double check the timing.
but at the same time i dont know why id wanna spend more money to fix the problem when im doin a motor swap soon
Old Feb 16, 2008 | 05:36 AM
gourley's Avatar
Default Re: Sluggish???? HELP ASAP!!!! (RunninEg6)
the z6 dizzy wont fit, you need a y8 dizzy. switch the plug, set the timing. /thread
Old Feb 16, 2008 | 05:39 AM
I must say letting it sit there is not dumb at all... one hour would not have hurt it. The car it self has been at rest for 6 months and letting it run a while its a pretty damn good idea. Your andswer to ur question yes it idles just fine, but when you try to take off sluggish then picks up.</TD></TR></TABLE>
i must say the proper way to doing it is let it warm up then shut it down. let it cool then start back up warm up. depending how long it sat for, should also change the oil. then go for a drive at different speeds. letting a car idle is alot of wear than you think
Old Feb 16, 2008 | 10:27 AM
SH's Avatar
SH
i must say the proper way to doing it is let it warm up then shut it down. let it cool then start back up warm up. depending how long it sat for, should also change the oil. then go for a drive at different speeds. letting a car idle is alot of wear than you think</TD></TR></TABLE>
As changing the oil that would be done once the car is running right and then test drive it.
ozh_hawaiian
Oct 14, 2012 01:20 PM
chickenwing
Nov 15, 2008 06:30 AM
jb0705
Jul 6, 2008 07:18 AM
EJ6_Hatch
Aug 13, 2007 09:14 AM
dthug
12
Dec 18, 2006 02:08 PM
