can I use a manual throttle body on auto?
Old Feb 11, 2008 | 10:01 PM
Derek128's Avatar
Default can I use a manual throttle body on auto?
someone is selling his enlarged ported & polished throttle body(off from a manual CB7 f22a4)
can I use it on my auto cd5(f22b1)?
I believe its bolt on
but i worry about the throttle control cable
I know someone is using auto throttle body on manual
but i wonder the other way around
thx
Modified by Derek128 at 6:18 AM 2/12/2008
Old Feb 11, 2008 | 10:45 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: can I use a manual throttle body on auto? (Derek128)
dood IMOP dont waste your money on that **** its not gonna help much with a stock IM.
Old Feb 12, 2008 | 03:07 AM
m735is's Avatar
You can swap the part of the throttle from your auto to the manual one so that the cruise control and tranny cable have a place to go to. But also check whatever is attached to the throttle. On one of my Civics, I swapped in a manual motor into my auto car and had to change the thing on the throttle body (I can't remember the name of it - idle valve thing). The manual and auto cars used a different one.
To double check the parts you want to swap, go to Majestic Honda and compare parts of the throttle bodies.
Whether or not it's a good idea, I have no clue.
Old Feb 12, 2008 | 03:27 AM
cb900f2's Avatar
Do you mind me asking where did you get the pdf version of the service manual?
thanks
Old Feb 12, 2008 | 05:11 AM
Derek128's Avatar
Default Re: can I use a manual throttle body on auto? (m735is)
here is the f22a4 manual tb
http://www.hondaautomotivepart...+BODY
here is the f22b1 auto tb
by looking @ this 2 graphs
I can't find the MAP SENSOR SET (#21) in the f22a4
Old Feb 12, 2008 | 05:13 AM
Derek128's Avatar
Default Re: (cb900f2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb900f2 &raquo;</TD></TR><TR><TD CLASS="quote">Do you mind me asking where did you get the pdf version of the service manual?
thanks
http://www.hondahookup.com
Old Feb 12, 2008 | 06:27 PM
BlUAc's Avatar
Default Re: (Derek128)
I hate to brake it ot you but the bolt pattern is diff between the two im. And also the fast idle valve is mounted on the tb on the f22b and not on the f22a
Old Feb 12, 2008 | 08:13 PM
Derek128's Avatar
Default Re: (BlUAc)
O.... right
thx everyone
Iloveyourhonda92
Sep 22, 2011 05:17 AM
calvin924597
Jan 29, 2010 06:24 AM
eh3 93
Jul 13, 2006 08:51 PM
onefastrx7turbo
Nov 9, 2005 05:17 PM
igo4bmx
Apr 8, 2004 08:04 AM
