Trailing arm bushing "clocking" question
Old Feb 11, 2008 | 08:16 PM
alscrx's Avatar
Default Trailing arm bushing "clocking" question
Of course i have searched and came up with some info. Not all that good with math but someone had a formula to figure out the correct position for clocking the trailing arm bushings....i was lost trying to figure it out
Thing is i bought a rear disc conversion so they are NOT on the car now for me to mark them!!! So i am not really sure how to "clock" them correctly.
I am lowered 1.25" on tokico's springs
Can anyone shed some light?
Old Feb 11, 2008 | 09:17 PM
whiteknightef's Avatar
Default Re: Trailing arm bushing "clocking" question (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Of course i have searched and came up with some info. Not all that good with math but someone had a formula to figure out the correct position for clocking the trailing arm bushings....i was lost trying to figure it out
Can anyone shed some light?</TD></TR></TABLE>
clock? If you bought a rear disc conversion throw it on with some energy suspension solid bushings. clocking?
Old Feb 11, 2008 | 09:28 PM
alscrx's Avatar
Default Re: Trailing arm bushing "clocking" question (whiteknightef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">
clock? If you bought a rear disc conversion throw it on with some energy suspension solis bushings. clocking?</TD></TR></TABLE>
Yes clocking is a term for correctly positioning the rear trailing arm bushings so there is no pre load twist once installed. If they are not clocked properly the bushing will get premature wear!
Energy suspension bushings suck and so cause binding in the rear. They are way to hard!
Old Feb 12, 2008 | 04:23 AM
CRX Toad's Avatar
I put mine on a slight angle when I put them also. Now that I am lowered down for track duty the bushing sits flat. Rides nice too and I have not "twist" or "binding" of the bushing. Check this out, it will help you http://www.performanceforum.co....html
Old Feb 12, 2008 | 07:13 AM
dr_latino999's Avatar
Default Re: Trailing arm bushing "clocking" question (CRX Toad)
c^2=a^2+b^2
A=distance from bushing to lower control arm mount (inches)
B=Drop of car (inches)
arctan(b/a)=angle of clocking
Old Feb 12, 2008 | 07:51 AM
alscrx's Avatar
Default Re: Trailing arm bushing "clocking" question (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">c^2=a^2+b^2
See what i mean....just looking at this sh@! give me a headache
Can you help me figure that out????
Old Mar 22, 2008 | 07:16 PM
Dark Star's Avatar
does it actually have to be pressed in by a shop or can u do it urself ? and can a broken bushing cause shocks to blow out ? ive had to shocks blow out and i just noticed the bushing was broken , ive always heard a knocking noise and i never could figure it out until i seen that broken bushing.
Old Mar 25, 2008 | 01:47 PM
alscrx's Avatar
Default Re: Trailing arm bushing "clocking" question (Dark Star)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark Star &raquo;</TD></TR><TR><TD CLASS="quote">does it actually have to be pressed in by a shop or can u do it urself ? and can a broken bushing cause shocks to blow out ? ive had to shocks blow out and i just noticed the bushing was broken , ive always heard a knocking noise and i never could figure it out until i seen that broken bushing.</TD></TR></TABLE>
If you buy the tool you can do it yourself....its a bushing xtractor
Old Mar 26, 2008 | 10:20 AM
But the tool doesn't do 90-93 Integra trailing arms, and if you try to use it on the DA arms you'll break the tool.
Old Mar 26, 2008 | 01:39 PM
Crx Jimmy's Avatar
you only have to turn it a 1/4- 3/8" or so.
Old Mar 26, 2008 | 01:52 PM
dem0nk1d's Avatar
http://www.thepartsbin.com/rep....html
i bought these, solid poly bushings no binding and no need to align them.
Old Mar 26, 2008 | 02:31 PM
schardbody's Avatar
i always do quarter inch rotation per 1" drop. so about 3/8" cocked should be almost perfect.
sk8board{Pete}
Oct 22, 2008 09:17 AM
huge230
Aug 23, 2005 12:28 PM
b20bvtec'd
Mar 28, 2005 07:59 PM
unknown0001
Sep 3, 2004 01:41 PM
eghatchproject
Mar 16, 2004 07:05 AM
