Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Best place and deal to buy takta harnesses???
Old Feb 11, 2008 | 03:57 AM
DeDonDeRosa's Avatar
Default Best place and deal to buy takta harnesses???
looking to find where i can get the best deal for takata harnesses (long ones). if anyone knows where please let me know im looking for a set!
thanks guys
Old Feb 11, 2008 | 04:14 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Best place and deal to buy takta harnesses??? (DeDonDeRosa)
http://www.weaksauce.org
http://www.jhpusa.com
marketplace on here
Alot of people will tell you to not run the long versions to the rear seat belts, and not to run takata cause there are harnesses that are cheaper that are just as good. just a heads up
Old Feb 11, 2008 | 04:19 AM
Default Re: Best place and deal to buy takta harnesses??? (B16B_coupe)
yea i know cheaper belts that doo the same thing are out there
it is ok to run them to the rear seat belt correct??? thats what takata told me to do, as long as its on a certain degree angle.
Old Feb 11, 2008 | 04:34 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">yea i know cheaper belts that do the same thing are out there
it is ok to run them to the rear seat belt correct??? that's what takata told me to do, as long as its on a certain degree angle.</TD></TR></TABLE>
Not without a roll bar, I still wouldnt recommend it.
I would get a min get a roll bar
do a search for "harness" you will find lots of info
Old Feb 11, 2008 | 04:55 AM
yea i have heard people say that, about having a roll bar. but why is not good to have harnesses with no roll bar? i never knew the answer 100%
Modified by DeDonDeRosa at 6:09 AM 2/11/2008
Old Feb 11, 2008 | 05:33 AM
B16B_coupe's Avatar
HRD PKR
Searching would give you more info but.
But think about a 4pt/5pt harness your strapped in an up right position, in roll over at the track your goin to get crushed because your body wont be able to move like a normal 3pt belt.
HERE is some links to help you
https://honda-tech.com/zerothread?id=2195990
https://honda-tech.com/zerothread?id=2148231
Old Feb 11, 2008 | 06:12 AM
thank you for the info
what about using them for street driving??
i will check out those links thanks again
Old Feb 11, 2008 | 06:15 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">thank you for the info
i will check out those links thanks again</TD></TR></TABLE>
Alot of people are against it, But i'm sure alot of people use them.
I've read places that say its hard to check your blind spots, or move around in your car to get a drink etc.
I'm sure someone else will come in here with there opinion soon
Old Feb 11, 2008 | 06:25 AM
thank you very much.
yes i was going to bolt them to the rear seatbelt on the floor and make sure the driver seat is positioned up.
i know it can be dangerous if you dont have them at a certain angle
Old Feb 11, 2008 | 06:40 PM
Chris F's Avatar
Try the freaking appearance forum
Old Feb 12, 2008 | 10:18 AM
carrnut21's Avatar
I would not use ever use a harness for street driving without a roll cage or bar, and even then they are really only useful for the track. When you sit in a seat with the harness tightened down, you can't move your body around. Checking your blindspots or reaching for something as simple as the radio/climate control could become a chore. Also, think about if you were to roll, your neck and body would be fixed in an upright position and your head could be crushed by the roof collapsing. If you had a regular seatbelt on it would be much easier to slide your body down and avoid certain death.
Old Feb 12, 2008 | 10:46 AM
Default Re: (carrnut21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Try the freaking appearance forum </TD></TR></TABLE>
dont cry !
thanks for the info guys
Old Feb 12, 2008 | 12:05 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (DeDonDeRosa)
i think you posted this in the ITR forum as well. anyway blueR has the harness for you and i did daily drive with a harness before i got a rollbar and i feel really foolish for doing so but the mounting point on the door side prevented me from running the stock OEM belt.. no that i have a roll bar.. im set.
Old Feb 12, 2008 | 12:59 PM
rotten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">yea i know cheaper belts that doo the same thing are out there
it is ok to run them to the rear seat belt correct??? thats what takata told me to do, as long as its on a certain degree angle.</TD></TR></TABLE>
You should try to keep the length of the belts to a minimum. There have been cases (such Roj Freeth--Possum Bourne's co-driver) where the occupants have been crushed due to the long belt configuration. Stretching is also an issue.
Frankly, unless there is something your stock belts aren't doing for you currently: i.e. you're not competing in a motorsport category that requires them, I wouldn't screw around with harnesses. If this is about bling (and it seems to be, otherwise why would you be asking specifically about Takata), I'd recommend thinking more about safety and less about appearances.
GaetanoL
Nov 28, 2010 08:13 AM
95dxsir2
Nov 5, 2007 10:20 AM
EFinawesomeman
May 17, 2007 09:42 PM
Lucky-13
Feb 25, 2007 08:30 AM
rzarecta123
Aug 16, 2004 07:15 AM
