Help with Climate Control light not working?
Old Feb 10, 2008 | 07:15 PM
elmejor's Avatar
Default Help with Climate Control light not working?
My Climate Control light is not working i went and bought 2 # 74 lights and i put them in ( even though they were a little to big and i had to force them in) and after putting the new ones they are still not working, what can be the problem maybe a fuse even though i doubt it, can someone help with this problem, i know its not a big deal not having that light but if can fix it i will.
Old Feb 11, 2008 | 12:25 AM
slowcivic2k's Avatar
Default Re: Help with Climate Control light not working? (elmejor)
Tell us what car you have. A Chevy Nova perhaps? If that is the case, junk it.
Old Feb 11, 2008 | 12:34 AM
BlueIntegraBoy's Avatar
Your dimmer switch might be bad if your cluster lights don't work either
Old Feb 11, 2008 | 01:04 AM
Default Re: Help with Climate Control light not working? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Your dimmer switch might be bad if your cluster lights don't work either</TD></TR></TABLE>
Was going to say that as that happened in my 91 hatch, the 88-91 has a two piece control unit, and the 92-up's have a single unit built into the dial.
Old Feb 11, 2008 | 04:39 AM
elmejor's Avatar
i have a 1992 honda civic EX
Old Feb 12, 2008 | 01:20 AM
Does your dash dimmer work? And were the bulbs you replaced bad? Don't replace parts until you know what the problem is, that way you have more information on the problem.
Have you done anything in the dash? (Stereo etc..)
Old Feb 12, 2008 | 11:00 AM
blk92_d16's Avatar
Since I don't have a Helms at work, are 74s the correct bulb for the HVAC? You say they were difficult to get in as if they weren't the right ones or something. Yes, does the rotary dimmer switch work for your cluster lights?
bonkerzz
21
Nov 6, 2011 10:14 AM
got00rice
24
Feb 8, 2010 06:17 PM
JDM_EK_wanabe
Sep 28, 2006 02:03 PM
usdmEHboy
Feb 1, 2006 08:30 AM
92eg6
Jul 25, 2004 10:03 AM
