Stuttering, random check engine light.
Well i am kinda stumped on this one. I have a 95 hatch, with a b18c1. Running a P72 with just the stock base map on it. The only recent thing i have done was installed a skunk2 intake manifold. What happens is this, when im just cruising around town sometimes it'll stutter/hesitate what ever ya call it. When i gun it sometimes it'll be revving like normal and hesitate and vtec will disengage. I have replaced the distributor cap and rotor, spark plug wires, spark plugs as well and the problem is still there. Other than that, i am not sure what else could be causing this problem. With the CEL, i haven't been able to pull the code yet, because when i turn the car off, and then back on, its gone. I am assuming that the problem may be a sensor or something. When i get the chance i will have to datalog the car and hopefully that will help me figure out what is goin on. Anywho any input would be greatly appreciated. Thanks guys
Last time I did any major work on my B16A2, one of the things I replaced was the throttle body gasket, and when everything was put back together I would randomly getting a flashing CEL, the engine would jerk around, and my idle was freaking out (I also had a slight leak in the intake). I remove the throttle to find that I installed the gasket the wrong way and so it was leaking and interrupting the MAP sensor. I realized that I made the mistake of trying to match the gasket to the manifold mating surface rather than the throttle body mating surface. Replaced the gasket again and she purred like a kitten.
By the way, you can tell if it's installed correctly without taking anything apart because there will be a little tab on the gasket sticking out on the upper corner of the throttle body closest to the firewall.
interesting input
. I will also check the light the next time it comes on. Just thought in the mean time i might ask yall what to possibly look at before i am able the check the code again (doesn't show up that often which is why i am askin you guys in the meantime)
