Component Location: KEYLESS DOOR LOCK/SECURITY CONTROL UNIT 1997 Accord SE
Old Feb 10, 2008 | 05:42 PM
KidFrost's Avatar
Default Component Location: KEYLESS DOOR LOCK/SECURITY CONTROL UNIT 1997 Accord SE
does anyone know where is.... i am tring to find out why my keyless wont work. thx guys
Old Feb 10, 2008 | 06:27 PM
TheMuffinMan's Avatar
He knows where you live!
As far as I know. It should be located near your inner fuse box.
There's a 3 wire connector that goes to it.
Old Feb 11, 2008 | 03:56 AM
KidFrost's Avatar
Default Re: Component Location: KEYLESS DOOR LOCK/SECURITY CONTROL UNIT 1997 Accord SE (KidFrost)
no you must be thinking of something else ... it has an 18 pin connector and a 12 pin connector...
the first step in the test procedures it to move the drivers seat forward.. but is it under the back seat or the carpet b/c its not under the drivers seat
Old Feb 11, 2008 | 05:50 AM
fcm's Avatar
fcm
Old Fart
This is what the door lock control unit looks like... http://cgi.ebay.com/ebaymotors...sting this is for a 2 door, except the SE.
There is only one plug into it, the key-less entry RF module is located above the fuse box, single gray plug plugged into it, the OEM alarm module is under the pass. seat, if I remember correctly the door lock module is under the drivers seat, attatched to the seats front mounting brace.
What exactly is the problem with the door locks. 94
Old Feb 11, 2008 | 01:21 PM
KidFrost's Avatar
Default Re: Component Location: KEYLESS DOOR LOCK/SECURITY CONTROL UNIT 1997 Accord SE (fcm)
well i bought the car used obviously and when i did it didnt have a battery in the fob and once i got a bat the keyless wont work .. i tried all the relearn procedres but to no avail.. so now what to do??
Old Feb 11, 2008 | 01:23 PM
KidFrost's Avatar
plus it is infact an se
Old Feb 11, 2008 | 07:33 PM
fcm's Avatar
fcm
Old Fart
Do the power door locks work normally, lock and unlock with the switch?
If you use your key in the drivers door, does the pass. door lock and unlock when you lock and unlock the drivers door? 94
Old Feb 12, 2008 | 10:04 AM
KidFrost's Avatar
yes it does ... both w/ the switch and w/ the key
Old Feb 12, 2008 | 06:29 PM
fcm's Avatar
fcm
Old Fart
That means the problem is definitely in the key-less entry module.
Although it does not matter any more, the SE door lock control module looks pretty much the same.
Is there an alarm module under the pass. seat? 94
Old Feb 13, 2008 | 05:21 PM
KidFrost's Avatar
idk i will go check.. how big is it ?
Old Feb 14, 2008 | 05:49 PM
KidFrost's Avatar
yup there is
you belive this is my problem??
Old Feb 15, 2008 | 05:18 AM
fcm's Avatar
fcm
Old Fart
If it has the R/F section in it then yes, does it have a FCC number on it? 94
Old Feb 16, 2008 | 05:02 PM
KidFrost's Avatar
r/f sectio??
Old Feb 17, 2008 | 06:20 AM
fcm's Avatar
fcm
Old Fart
RF section is the "radio" that receives the signal sent by the transmitter. 94
Old Feb 17, 2008 | 04:46 PM
KidFrost's Avatar
if this is in fact my problem and i get a new one how do i program my transmitter to the new unit???
Old Feb 18, 2008 | 05:15 AM
fcm's Avatar
fcm
Old Fart
You will have to check with Honda for programming. 94
dougaccordwagon
Jul 21, 2015 03:27 PM
battle2.0ek9
18
Aug 31, 2013 05:53 PM
govtec
Audio / Security / Video
12
Oct 10, 2011 01:46 PM
Tims Toy 500
Sep 6, 2010 12:49 AM
slikz714
Sep 16, 2008 05:21 PM
