coolant temp sensor
Old Feb 10, 2008 | 01:28 PM
packman5280's Avatar
Default coolant temp sensor
getting code p0117, coolant temp sensor on a 2000 civic si. i changed the one up by the vtec switch, still getting the code. there is another one on the back of the block, is there a way to tell if that one is bad or if i have a wiring problem? thanks.
Old Feb 11, 2008 | 07:43 AM
bump, anyone have any ideas? the car is idling at about 1400 even after it warms up, and vtec never comes on, so i'm pretty sure the ecu thinks it isn't warmed up properly.
Old Feb 11, 2008 | 07:53 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (packman5280)
You have the coolant temp switch, coolant temp sensor, fan switch, thermostat.
Probably your temp switch.
Old Feb 11, 2008 | 08:39 AM
hmm, so which one is which?
Old Feb 11, 2008 | 10:36 AM
another quick question, would this sensor keep me from setting timing correctly? i warmed the car up till the fan came on, turn offf the car, jumped the service connector, started it back up, then set the timing to the middle of the three marks. it was running fine yesterday, but this morning it really didn't want to start. was sputtering like the timing was off. it finally started, but barely touching the gas pedal would almost kill it. any ideas?
Old Feb 12, 2008 | 11:20 AM
ok so the sensor is for sure causing the starting problems. now i just need to figure out which sensor it is, there ae three of them that i know of; by the vtec sensor, on the t-stat housing, and the back of the block under the intake. however, it could be wiring. i just unplugged all the snsors and made sure they were plugged in really good, then checked the codes, and the vtec code is back. i replaced that switch with the one from my a2 to get that code to go away, now it's back. so, now what? any help is much appreciated.
Old Feb 12, 2008 | 01:52 PM
ok i'm dumb. the sensor on the back is probably the knock sensor, and i realized i had my the two plugs (vtec and ect) switched around. switched them back and al is well now. thanks for the help.
Old Feb 12, 2008 | 02:07 PM
Perfectionist's Avatar
Default Re: coolant temp sensor (packman5280)
I just read your post. Thanks for the update. FWIW, my old Civic had 3 temp sensors. The one at the back of the block ran the radiator fan. There were two at the T-stat. One fed the temp guage, the other told the ECU the engine temp and could cause starting issues if it got flakey.
kramer06
Jan 24, 2008 05:41 PM
hondaccordguy
Dec 10, 2006 07:23 PM
whiterex
Feb 28, 2005 02:57 PM
