Best D15 block?
Old Feb 10, 2008 | 12:09 PM
95CoupeDX's Avatar
Default Best D15 block?
just curious, what d15 is the best? As far as being the strongest and which has the highest compression pistons? Any input would be great, thanks.
Old Feb 10, 2008 | 01:42 PM
xd69's Avatar
Default Re: Best D15 block? (95CoupeDX)
I would say the D15B JDM block is the best D15
Old Feb 10, 2008 | 02:54 PM
Skunk.Werks's Avatar
Default Re: Best D15 block? (xd69)
Well the D16a6 is 'supposedly' the strongest bottom end because of the iron main girdle opposed to the aluminum mains on the rest of D16 motors. The D15b uses abnormal sized internals that prevent you from install off the shelf components like Golden eagle rods etc. you have to mix and match parts from D15z1 (VX) and other custom **** so I've heard.
So to cut to the chase, the best 'D' motor for you is most likely going to be a D16z6. You can find after market or replacement parts all day long and if you are looking for HP you can put a Z6 into the 12's for relatively low costs with a well made turbo kit.
Old Feb 10, 2008 | 03:30 PM
zeddy's Avatar
i would go with jdm d15b vtec ! they make more hp then the z6! and you can still put all the z6 parts on it
Old Feb 11, 2008 | 04:28 PM
95CoupeDX's Avatar
Default Re: (zeddy)
well i have a z6 head and i wanted a 1.5 block(D15's have always been good to me, plus i like them for the gas milage) so i didnt know what block was the best. I guess ill be going with just a B7?
JDMCL
20
May 17, 2011 06:22 AM
wernhersey
Dec 27, 2007 07:52 AM
Bimmer99
Jun 12, 2006 06:27 PM
tobe1424
12
Dec 6, 2005 07:01 PM
Daniel san
11
Mar 7, 2005 08:10 PM
