best bottom end and head
Im going sohc boost...wanna build a single cam...simple easy to mess with cheap...out of all the d16's whats the strongest block i can use out there and the best vtec head...if there not all the same just wondering..if not i was going to get a hold of a d16y8
Re: best bottom end and head (tobe1424)
honestly, as far as i know the z6's/y8's are great engines to build...but ive also heard that actually boosting a D15 w/ a vtec head(if vtec is what you want) is a better choice b/c the blocks hold up better...but i cant say for sure...
Re: best bottom end and head (PnkRokCountryboy)
well id rather keep a y8 then ...parts are easier to find...by any chance you know where i can get a cheap sleeved block to be on the safe side
Arguably, the A6 bottom end is one of the strongest of the D series engines. Both the Z6 and Y8 are very similar, and would net similar results. As far as the USDM D15 - it has smaller rods which are prone to failure if exposed to detonation. The A6/Z6/Y8 and JDM D15B (which has Z6 rods) are more robust in this respect, but any detonation is really undesireable.
There are some people who have experienced main bearing failures on the Y8's, which some have also attributed to reduction in output from the oil pump as opposed to the Z6. This hasn't been proven to no doubt, but it is something to consider. If either the Z6 or A6 is available, I'd most likely pick one of them (price and mileage if not rebuilding are also considerations).
My $.02
My $.02
how much pis do you plan on running? internals etc. can you give more details and what kind of #'s you're looking for...if you're looknig for something small a sleeved block probably isnt necessary, but you're looking to probably spend about 8 dollars on a sleeved used block( http://www.hondamarketplace.com is where the deals are at)
i think that you can get away w/o sleeving the block for sure, if you're trying to save money ...but sleeving is def. not a bad idea and is always reasurance
well if sumthing tops around 350 or more whp nothing major i just wanted to not have a bad feeling about the sleeves and have no worries on my mind
yea i know im pretty sure with the numbers that i more or less want i dont need sleeves as long as i have proper tunning...but like i said... dont wanna have sleeves on my mind at the track .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 »</TD></TR><TR><TD CLASS="quote">well if sumthing tops around 350 or more whp nothing major i just wanted to not have a bad feeling about the sleeves and have no worries on my mind</TD></TR></TABLE>
Are you saying you want to get 350 out of a sohc?!
If you are... you'll never make that much, especially if you plan to keep the stock bottom-end.
The sohcs have been good for 200-250-ish w/ good tuning on stock-block.
Re: best bottom end and head (mwieczorek43)
what he said ^ is true...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 »</TD></TR><TR><TD CLASS="quote">well yea im planning on fully building it </TD></TR></TABLE>bigger #'s can be achieved for sure, but 350 is pushing it on stock sleeves and also the longivity of the engine..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 »</TD></TR><TR><TD CLASS="quote">
The sohcs have been good for 200-250-ish w/ good tuning on stock-block.</TD></TR></TABLE>
he said he was fully building it.
if you have the extra 1k now, just spend it on the sleeves. good peace of mind when runing 300+
platinum.
platinum.
Re: best bottom end and head (platinum00)
yea i know ima go ahead and do that...ls bottom ends hold lots of boost of stock bottom end but then again im going single cam..like it better more simple and want to impress ppl...but yea ima fully built it ...i wanna do 350 hp..that doesnt mean ima drive it everyday at 350 lol...thats only for racing purposes
fsteclipsegst01
07-10-2007 05:28 PM
