eng. overheat
Old Feb 9, 2008 | 09:29 PM
ebabasa's Avatar
Default eng. overheat
One fan does not work. What is the probable cause?
Old Feb 9, 2008 | 11:37 PM
ifIexplode's Avatar
what year car?
what motor?
For all we know you could be driving a dump truck.
have you checked the fuse?
Old Feb 9, 2008 | 11:47 PM
Frozen E's Avatar
H-T White Ops
ONE fan?
If you're driving a civic you only have ONE fan. Radiator fan that is.
The other one is your condenser fan for your AC.
Check coolant level.
Done anything that required the cooling system to be opened up lately? (thermostat, head gasket, radiator hose, etc)
If so, you may have air pockets
Could be a bad water pump as well
Old Feb 9, 2008 | 11:48 PM
meandino's Avatar
Default Re: eng. overheat (ebabasa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebabasa &raquo;</TD></TR><TR><TD CLASS="quote">One fan does not work. What is the probable cause?</TD></TR></TABLE>
Plug it in.. Maybe its your a/c fan??
dubyada
Honda CR-V & Element
Aug 21, 2014 10:12 AM
o5va1d0
Honda Civic (2001 - 2005)
Sep 5, 2011 04:30 AM
qwk db8
Oct 7, 2007 06:43 PM
f1 vtec
Jan 27, 2006 04:43 PM
wnadance
Sep 25, 2004 11:24 AM
