Boost by Gear install***HELP***
Old Feb 9, 2008 | 08:42 PM
evild16's Avatar
Default Boost by Gear install***HELP***
I search for a tread on this already but could not find. I wanted to know if there is anyone out there that can provide me a complete diagram on how to properly install the boost by gear controller. Pics of your installs would be great but drawing diagrams will work also. Just want to know the correct sequence or order to install the vacuum lines. Any and all help will be greatly appreciated.
Old Feb 9, 2008 | 08:48 PM
melovesboost's Avatar
well it would help to know what system you were actually using
Old Feb 10, 2008 | 01:01 AM
IT'S ME DAVID's Avatar
NooB
Default Re: (melovesboost)
most likely s300
Old Feb 10, 2008 | 10:04 AM
mtber's Avatar
Default Re: Boost by Gear install***HELP*** (evild16)
If you are using s300, simply click the help tab & search
Old Feb 10, 2008 | 04:49 PM
urnotfast's Avatar
if you are using an avc-r here is a link on how to set up boost by gear
https://honda-tech.com/zerothread?id=1037051
Old Feb 10, 2008 | 06:56 PM
evild16's Avatar
Default Re: Boost by Gear install***HELP*** (urnotfast)
well guess everyone misunderstood my troubles. I actually need to know how to install the boost by gear solenoid. I already have my system setup, Hondatas300 of course, and i have no problems there. I just want to make sure that I hook the vacuum ports correctly to the wastegate and the turbo. Please post any pics of your solenoid install or diagrams you may have to help me. This is the one that i am using.
http://www.t1raceparts.com/Pro...t.htm
Old Feb 10, 2008 | 08:06 PM
zex_cool's Avatar
hope you didnt pay that much.
fyi; http://www.xenocron.com/catalo....html
you can get them for even cheaper.
anyways, one port goes to the WG and the other to a vac source. jst like any other boost controller.
Old Feb 12, 2008 | 10:21 AM
zex_cool's Avatar
Default Re: (zex_cool)
i was wrong, here is a pic of how to.
Old Feb 12, 2008 | 02:42 PM
turbotypeR@SPEC's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evild16 &raquo;</TD></TR><TR><TD CLASS="quote">well guess everyone misunderstood my troubles. I actually need to know how to install the boost by gear solenoid. I already have my system setup, Hondatas300 of course, and i have no problems there. I just want to make sure that I hook the vacuum ports correctly to the wastegate and the turbo. Please post any pics of your solenoid install or diagrams you may have to help me. This is the one that i am using.
http://www.t1raceparts.com/Pro...t.htm</TD></TR></TABLE>
if you look under the help/ contents file there is a boost control solenoid installation diagram
streetsports1
Engine Management and Tuning
Jan 11, 2014 05:29 AM
kmaz93da
Jun 3, 2010 09:27 AM
kmaz93da
Jun 2, 2010 06:24 PM
Hoosier Daddy
Dec 25, 2003 04:32 PM
Aeka GSR
Sep 30, 2003 06:20 AM
