tune without ems on stock pcm?
Old Feb 9, 2008 | 02:55 PM
ericstambaugh07's Avatar
Default tune without ems on stock pcm?
i built an h23 and boosted it and got ripped off on ebay..i bought a used emanage and tryed to use it a couple months later..the thing is expletiveed it wont work..so im out of money and i have no ems..can i get a good enough tune on 6lbs with a t3 on my stock pcm?
Old Feb 9, 2008 | 03:22 PM
boostedh22lude1's Avatar
Default Re: tune without ems on stock pcm? (ericstambaugh07)
you cant tune a stock ecu
Old Feb 9, 2008 | 04:12 PM
Default Re: tune without ems on stock pcm? (boostedh22lude1)
yeah i kno that u can re flash or w.e u wanna call it to a stock pcm. u can go in and change things like timing, rev limiter, ect. but i dont kno if it will be enough for a turbo application
Old Feb 9, 2008 | 04:14 PM
Schister66's Avatar
Man U FTW
The only way to use the stock ECU is by way of a piggy back, but there aren't any good ones offered as far as i know. The easiest method is a chipped OBD1 ecu
Old Feb 9, 2008 | 08:03 PM
mtber's Avatar
Some stock ecus can be modified to be tuned with. I recommend you read over http://www.phearable.net/tech/....html for a better understanding.
miggy23
Engine Management and Tuning
Apr 26, 2019 11:45 AM
954bballer091
Sep 13, 2008 07:38 PM
ericstambaugh07
Feb 11, 2008 05:11 AM
Keangdawizes
Apr 5, 2006 07:26 PM
TRuST
Jan 18, 2002 04:03 AM
