My Baby Crapped Out On Me
Old Feb 9, 2008 | 01:51 AM
oovvutt's Avatar
Default My Baby Crapped Out On Me
So I was coming home late at night, my car (93 EJ1) ran awesome like it allways does, no problems what so ever. So im cruising on the highway, about to get off at my exits, and out of nowhere I feel a power loss, my rpms fall, and my car dies out. So I roll into the exit in neutral with my car off. Get about half way onto the ramp, pull over and crank it. It starts, idles for 2 seconds and dies agen. I keep cranking, but it doesnt start. I crank it and give it a little gas, but as soon as I let go of the gas, my baby dies. So there I am, so close to home, but no way to get there. I let the car stand for a little while, crank it agen and bam starts up but then dies, and its all over agen. I checked the spark plug wires, dizy, any bad connection (that i can see) everything seems to be in order. I turn the ignition on and off to listen to the fuel pump noise, but it doesnt make one. I think thats what might have crapped out on me. What ever, called my Dad, he pushed me with his car all the way home. Gonna try and see what was the problem. Anyone have any clue?? Pretty happy that my baby made it close to home with its last breath.
Old Feb 9, 2008 | 04:23 AM
King V's Avatar
Default Re: My Baby Crapped Out On Me (oovvutt)
Stock? Mods? Fuel controllers? Etc......?
Old Feb 9, 2008 | 04:31 AM
oovvutt's Avatar
Default Re: My Baby Crapped Out On Me (King V)
All stock d15 non vtec...
Old Feb 9, 2008 | 05:26 AM
B18bEG6ick's Avatar
When you turn the key to on and off do you hear a clicking sound? From what you are describing from you story it seems like your distributor went bad. Check to see if you have spark and fuel.
Old Feb 9, 2008 | 05:39 AM
Dav94Lx's Avatar
Ok... so you should hear a small click right after you turn the key to accessories mode on your ignition. If you do not hear the small click. Then you should probably check your fuel management circuit board. I'm not really sure if thats the real name for it. But it should be located right next to your fuse box under the dash. I've had this happen to me once a while back, and there was a break in the curcuit. So I was getting not fuel to the motor. Freaking car started for a few seconds and died. Not sure if this is your exact problem. But you should probably check anyways. Good Luck!! and keep us posted.
Old Feb 9, 2008 | 06:55 AM
pkdog167's Avatar
Default Re: My Baby Crapped Out On Me (B18bEG6ick)
Stupid question, but is your tank empty??
Old Feb 9, 2008 | 07:11 AM
boosted92hatch's Avatar
check for spark first, if u got spark then dizzy is good. then pull up the seat and have someone turn the key on and off to the accesory position while u listen for the pump, if the pump turns on change the main relay.
Old Feb 9, 2008 | 08:58 AM
jhammond_82's Avatar
Reject Papi
Default Re: My Baby Crapped Out On Me (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">Stupid question, but is your tank empty??</TD></TR></TABLE> lol. i would agree with the distributor theory.
Old Feb 9, 2008 | 10:23 AM
oovvutt's Avatar
Default Re: My Baby Crapped Out On Me (jhammond_82)
well im gonna get into it right now, but guys just keep in mind, it just happened out of nowhere, without any signs or anything...
Old Feb 9, 2008 | 03:03 PM
oovvutt's Avatar
Ok I fixed it... B18bEG6ick and jhammond_82 you were right, that damned distributor. One of the contacts had like a burn off, so when i opened it up cleaned it up, and it started like a baby. Wohoooo
Old Feb 9, 2008 | 03:32 PM
Hater's Avatar
Default Re: (oovvutt)
When babies crap on me, I just change my clothes.
ZING!
Congrats on the repair.
Old Feb 9, 2008 | 09:38 PM
oovvutt's Avatar
lol thanks simple solution, but a headache to find out whats went wrong . I ve also noticed my dizzy is leaking oil? Wtf is that??
Old Feb 9, 2008 | 09:49 PM
1badteg's Avatar
there is a seal on the dizzy that needs to be replaced if its leaking. you will see if when you unbolt the dizzy.
Old Feb 9, 2008 | 09:59 PM
oovvutt's Avatar
Default Re: (1badteg)
Yeah i just searched H-T and it says it is the O-ring that needs to be replaced. Im gonna do it when it gets warm...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badteg &raquo;</TD></TR><TR><TD CLASS="quote">there is a seal on the dizzy that needs to be replaced if its leaking. you will see if when you unbolt the dizzy. </TD></TR></TABLE>
Old Feb 10, 2008 | 02:25 PM
oovvutt's Avatar
Died on me agen... I think this dizzy oil leak is causing a big problem...
Old Feb 10, 2008 | 02:29 PM
EG2Driver's Avatar
do a tuneup
Old Feb 10, 2008 | 03:32 PM
shizkabob3421's Avatar
Default Re: (EG2Driver)
try your main relay it controles the fuel pump and the ecu i had a problem were my car would do the same excat thing it would run for a few seconds then shut off..and the fuel pump would not come on..got the relay never had a problem.
Old Feb 10, 2008 | 04:15 PM
bboyjimpy's Avatar
hmmm maybe its the battery? orrr. the alt.
Old Feb 10, 2008 | 04:28 PM
oovvutt's Avatar
I got the dizzy off ***** covered in oil, all the gaskets seem to be allright yet somehow its leaking in. Gonna try some thing tommrow see if it makes a difference, and post back. and no, I was completely wrong with the fuel pump theory, thats completely fine...
chriskinlaw
Oct 17, 2017 10:35 PM
PinkMaggit
Aug 16, 2008 08:49 AM
Finger Lickin' good
Aug 22, 2006 01:41 AM
ekcivic9
May 29, 2006 08:16 PM
Ri5e
Apr 3, 2002 12:08 PM
