Need help whining noise
I get a whining/whistling noise. Whether the clutch is in or out, in gear accelerating, or stopped, it doesn't matter. I put a new ls haed on and new timeing belt.
i did use the search and found this it is almost the same but no sound
https://honda-tech.com/zerothread?id=2101288
the whining sound on youtube
http://www.youtube.com/watch?v=rm7tmGzU_yQ
Sounds nasty! Might it be the idler pulley bearing? Did you fit a new idler pulley? If it's the old one then it might not have made a noise if then old belt was a little loose, but might now if the belt tension is a bit tighter (?).
EP3CHRiS
Sep 22, 2011 04:16 PM
