best gears for ITR tranny?
i have a usdm itr tranny with 4.4 final drive...
my fith grinds.. so i am going to change it out...
but i want to know whats the best oem gears i can put in..
i can get any oem gears ect: gsr b16 and itr tranny gears..
i am using the tranny as a drag tranny. but still a street car.
Was it really necessary to bump a thread that had only been up for 8 minutes? Youve been a member for less than 3 months and you already have 2434 posts, 99% of them are useless bumps and nonsense. Please try and keep this to a minimum.
No it won't. Gears will still be the same.
ITR has the best gears already (of OEM).
MFactory 3/4 close gear set and get new stock 5th gear if you only use it for street and drag.
He has a U.S itr tranny. The Jdm ones come with the 4.7 FD. A U.S itr tranny is the same as a B16, but the itr will have stock LSD. Thats the only difference between them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all motor b20b »</TD></TR><TR><TD CLASS="quote">He has a U.S itr tranny. The Jdm ones come with the 4.7 FD. A U.S itr tranny is the same as a B16, but the itr will have stock LSD. Thats the only difference between them.</TD></TR></TABLE>I thought the ITR tranny had dual cone synchros as well.
Same synchros as all B series.
A final drive does not make your gears shorter. It simply gets you through the gears quicker and lowers your top speed for each gear.
I've gone from a 3.722 FD to a 4.714 FD then to 4.250 with a close gear set and the gear set made the best difference by far.
rodimus
23
Sep 26, 2003 09:01 AM
