**Rear Caliper piston seized. Need ASSISTANCE**
Old Feb 8, 2008 | 11:35 AM
BB4lude's Avatar
* B A N N E D *
Default **Rear Caliper piston seized. Need ASSISTANCE**
My Passenger rear caliper piston is seized on my 00 Si rear brakes. I am by no means a mechanic.. but have always changed my brakes pads myself.... etc. I was wondering how hard it is to change out a caliper?
Any help is appreciated thanks
Old Feb 8, 2008 | 11:37 AM
pdotjones's Avatar
Default Re: **Rear Caliper piston seized. Need ASSISTANCE** (BB4lude)
not that hard. its two bolts and the brake line, if im not mistaken...
Old Feb 8, 2008 | 11:39 AM
civtic's Avatar
you could probably free it, try greesing the guide pins, or even working the piston in and out (but make sure it doesn't pop out), worked for me!
Old Feb 8, 2008 | 11:41 AM
BB4lude's Avatar
* B A N N E D *
Default Re: (civtic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtic &raquo;</TD></TR><TR><TD CLASS="quote">you could probably free it, try greesing the guide pins, or even working the piston in and out (but make sure it doesn't pop out), worked for me!</TD></TR></TABLE>
The piston isn't moving at all, its been seized for a while by how the brake pads were worn. The outer pad was completly worn to nothing while the inner pad still had some life on it
Old Feb 8, 2008 | 11:45 AM
civtic's Avatar
oh well, as you said then easiest thing would be to just replace it. Very easy job as long as you've got someone to pump the pedal for when you bleed the system again.
Old Feb 11, 2008 | 01:24 PM
BrakeExpert's Avatar
if you run the clear hose for bleeing the fluid through the top coil of the spring, you can bleed the car yourself
Old Feb 11, 2008 | 01:30 PM
Crx Jimmy's Avatar
You do know the pistons need to be "spun" in not just pushed in like the front right?
If they are really seized just get 2 remaned ones, they should be like $50
Old Feb 11, 2008 | 01:47 PM
egsleepercivic's Avatar
Default Re: **Rear Caliper piston seized. Need ASSISTANCE** (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">You do know the pistons need to be "spun" in not just pushed in like the front right?
If they are really seized just get 2 remaned ones, they should be like $50</TD></TR></TABLE>
x2, the rears screw in also make sure to grease the guide pins
gl
jadmEM1
Jun 7, 2007 06:05 PM
Two_K Si
Jan 8, 2004 01:16 PM
crxcess
Oct 9, 2002 10:50 AM
wickedxbo1
Dec 30, 2001 07:51 PM
D
Aug 6, 2001 06:21 AM
