HELP TURBO GSR FUEL/TUNING ISSUES
Old Feb 8, 2008 | 07:58 AM
boostedblkef's Avatar
Default HELP TURBO GSR FUEL/TUNING ISSUES
i got a gsr swap in an 99 civic basically stock with im and tb a precision sc34,880 injectors ramhorn neptune tuned ok so heres the issue
the car ran good made 301 whp @ 8psi ran fine for about a month the one day while warming up the car just died and wouldnt start
so after messing with it and new plugs it started ran horrible wouldnt rev up was breaking up all over
so after testing fuel spark timing ect..
too much fuel pressure?
we removed the fpr and ran it directly back to the tank thing runs ok now but its running on 20psi fuel i slowly clamp the return line fuel pressure goes to around 30 it dies and wont start im stumped please help me out with any idea oh and i have replaced
ecu
dizzy
chip
injector's not stuck
no fpr
checked map sensor
fuel pump and NO CEL'S
i think im missing something stupid
and the car will idle and run all day @ 20 fpsi
Modified by boostedblkef at 10:42 PM 2/8/2008
Old Feb 8, 2008 | 11:54 AM
Default Re: HELP TURBO GSR FUEL/TUNING ISSUES (boostedblkef)
Old Feb 8, 2008 | 11:56 AM
boosted k20's Avatar
check ur map sensor
Old Feb 8, 2008 | 12:57 PM
Default Re: HELP TURBO GSR FUEL/TUNING ISSUES (boosted k20)
checked it has the proper readings
and swaped it
Old Feb 8, 2008 | 04:47 PM
Sr420Det's Avatar
Fuel pump?
Old Feb 8, 2008 | 06:40 PM
Default Re: (Sr420Det)
checked the pump its working correctly
Old Feb 9, 2008 | 07:31 AM
bueller?
Old Feb 9, 2008 | 02:42 PM
HondaCivicSiR1's Avatar
bump for some helpful input
Old Feb 9, 2008 | 03:31 PM
boosstboy's Avatar
Default Re: HELP TURBO GSR FUEL/TUNING ISSUES (HondaCivicSiR1)
so, you removed the fpr and ran the feed line to the rail then the line off that directly back to the tank? you won't get high fuel psi, no restriction. did you put a new pump in the car yet? put the fpr back on the car and route the lines how their supposed to go and recheck fuel psi with cycling the key a couple times. are you watching your afr's while doing any of this? if not, you really need a wideband to tell you if your too rich, causing the car too turn off from flooding from higher fuel psi. it may be something in the tunes parameters got corrupted throwing the car out of tune causing the issue.
Old Feb 9, 2008 | 04:18 PM
Default Re: HELP TURBO GSR FUEL/TUNING ISSUES (boosstboy)
fuel pump was replace before the car was tuned
Old Feb 9, 2008 | 04:33 PM
93supercoupe's Avatar
i think its apperant that its dumping too much fuel.ANd ur probably seeing 20psi because of ur bigger fuel pump.
What kind of AFR;s is it reading when its dieing?
Try a different ECU and reburn the chip.
Old Feb 9, 2008 | 06:50 PM
Default Re: HELP TURBO GSR FUEL/TUNING ISSUES (93supercoupe)
a/f is pegged rich non stop nothing changes
if i put the fpr back in it will not start the way its setup now is the only way it runs im to the point now were i beleive its a timing problem in the tune but not 100% sure
Old Feb 9, 2008 | 06:52 PM
tried multiple combinations of chips ecu's it only gets worse not better i guess its going to get retuned
SilverEK96
May 17, 2013 04:09 PM
hatche1
May 10, 2011 04:52 PM
HondaKid936
Nov 25, 2008 02:09 AM
turbod16y7vtec
Dec 5, 2004 08:39 AM
baonest1
May 7, 2003 02:50 PM
