Removed starter, flywheel spins freely???
Old Feb 8, 2008 | 12:40 AM
wakaranai's Avatar
Default Removed starter, flywheel spins freely???
I thought my starter was not expanding out enough to grab the flywheel. I checked both the new starter and the one that was on the car and they both expand all the way out.
I checked the flywheel and the teeth look fine.
Now here's the tricky part; when I had the starter off, I would push on the teeth on the flywheel and I could spin it in both directions???
This is really strange. Could it be that only the outer portion of the flywheel that has the teeth broke off from the rest of the flywheel???
Any tips greatly appreciated. Thanks. BTW this is on a b16a with a stock flywheel as far as I know.
*I apologize for double posting, but I figured I could get more exposure here and get a quicker response given that it pertains to a b16 in an Em1* thanks
Old Feb 8, 2008 | 02:50 AM
lv6l's Avatar
How freely does the flywheel spin both ways when you try to push it with your hands?
Old Feb 8, 2008 | 03:02 AM
Lordofdark176's Avatar
if you've ever turned the crank manually with a wrench you know its kind of hard to do, if you can turn the flywheel (connected to the rank) that easily there is deff something wrong.
Old Feb 8, 2008 | 03:20 AM
lv6l's Avatar
Default Re: (Lordofdark176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">if you've ever turned the crank manually with a wrench you know its kind of hard to do, if you can turn the flywheel (connected to the rank) that easily there is deff something wrong.</TD></TR></TABLE>
Yup. Thats why I ask how freely can he turn it. Because if that thing is spinning with just a few fingers rotating it; you got some serious problems.
Old Feb 8, 2008 | 07:26 AM
wakaranai's Avatar
Default Re: (lv6l)
I can spin it very freely. But when I push it towards the engine and then try to spin it, it seems to get stuck and becomes immovable again.
Old Feb 8, 2008 | 07:37 AM
Luserkid's Avatar
Default Re: (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">I can spin it very freely. But when I push it towards the engine and then try to spin it, it seems to get stuck and becomes immovable again.
Im confused by this statement. You could spin it (around like a clock any direction) freely but when you push on it (im guessing towards the motor) it gets stuck on something? Are you sure the flywheel is attached to the crank? Unless im missing something from your explaination your going to need to drop the trans. What was the car doing originally?
Old Feb 8, 2008 | 08:44 AM
civicwagonman's Avatar
Default Re: (Luserkid)
either your bolts fell out or your flywheel is cracked. maybe even the crank. time to pull it out.
Old Feb 8, 2008 | 11:27 AM
wakaranai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> You could spin it (around like a clock any direction) freely but when you push on it (im guessing towards the motor) it gets stuck on something?</TD></TR></TABLE>
Exactly.
The car was having a hard time starting--starter spinning but not turning the motor. Eventually, it stopped starting all together and now this is where the car stands.
Old Feb 8, 2008 | 12:14 PM
Malakai's Avatar
I would agree with the above, u need to pull the trans and get a better look.
Old Feb 8, 2008 | 01:15 PM
Schister66's Avatar
Man U FTW
You may have sheared off the bolts that hold the flywheel to the engine or they may have come loose. Either way, you're going to have to pull the tranny and fix that problem...
Old Feb 8, 2008 | 01:29 PM
mastakmk's Avatar
Default Re: (Schister66)
x2
Old Feb 8, 2008 | 05:28 PM
hall97civic's Avatar
Default Re: (mastakmk)
well, I've never seen a flywheel out of a honda, but maybe you somehow just knocked the ring gear off of the flywheel. I can beleive it if someone had put a new ring gear on the flywheel and not have done it properly. OR is somehow the ring gear got cracked.
later
Old Feb 8, 2008 | 05:30 PM
VRD^sam's Avatar
Default Re: (hall97civic)
wow i've never heard anything like this before...hope you get it fix
Old Feb 8, 2008 | 05:32 PM
oh, and not trying to be a smart *** or anything but I highly doubt that he would have sheared off the bolts that hold the flywheel to the crank. Also I doubt that he could be able to turn the flywheel if it is sitting in the bottom of the bell housing(assuming that he somehow broke the bolts holding the flywheel to the crank). I'm sticking with a broken ring gear. Reguardless, you need to take it apart.
Old Feb 8, 2008 | 05:37 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic &raquo;</TD></TR><TR><TD CLASS="quote"> you somehow just knocked the ring gear off of the flywheel. </TD></TR></TABLE>
thats sounds exactly like what happened. its spinning around the flywheel. i've seen it a few times.
Old Feb 8, 2008 | 06:55 PM
wakaranai's Avatar
Default Re: (Brick Top)
Thanks for the 411. It definitely sounds like a broken ring gear.
Old Feb 8, 2008 | 07:06 PM
meandino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">You may have sheared off the bolts that hold the flywheel to the engine or they may have come loose. Either way, you're going to have to pull the tranny and fix that problem...</TD></TR></TABLE>
X2
Old Sep 14, 2016 | 07:02 PM
01LUDEebp's Avatar
Default Re: Removed starter, flywheel spins freely???
I think I'm having the same problem was this ever figured out?
b16ej8jdm
Apr 3, 2010 11:41 PM
projectlude
Oct 8, 2008 07:06 AM
MrBui
Dec 23, 2002 10:29 AM
lilcasino
Aug 4, 2002 08:25 AM
quick108
Jul 13, 2002 02:18 PM
