Evolution H2B kit, alum or steel oil pan required?
Old Feb 7, 2008 | 05:44 PM
Ls1 FD3s's Avatar
Default Evolution H2B kit, alum or steel oil required?
I have the alum oil pan and when i put the cutout template on the oil pan for the grinding procedure, it doesnt line up worth a ****. In the picture provided with the kit, it appears to look like it has a steel pan. Which is hella thinner than an alum one and in theory according to me, would allow the cardboard template to fit properly. Can anyone clarify this for me?
Thanks to all that help.
Modified by Ls1 FD3s at 9:02 PM 2/7/2008
Old Feb 7, 2008 | 08:01 PM
Ls1 FD3s's Avatar
Default Re: Evolution H2B kit, alum or steel oil required? (Ls1 FD3s)
****, just realized i left the word "pan" out of the title
Old Feb 8, 2008 | 12:41 PM
gibsanez's Avatar
What on evo's kit do you have to grind? Because with QSD's kit, all you're grinding of the oil pan is part of the lip, so it wouldn't matter if it was made of alum or steel
Old Feb 8, 2008 | 04:05 PM
Ls1 FD3s's Avatar
Default Re: Evolution H2B kit, alum or steel oil required? (gibsanez)
you have to clearance the block and oil pan so the driverside axle hub/boot clears it properly. Otherwise without grinding it will interfere and not line up at all.
I guess if my friend had the damn trans here, i could grind till its clearanced all the way, but he doesnt, so all i have to go off of is this template. Bottom line, i dont want to mess it up, rather have ideal conditions rather than try and reinvent the wheel as i go.
Old Feb 8, 2008 | 08:42 PM
gibsanez's Avatar
Ok, so it's the same with QSD's kit, and all I did was grind away until I made enough room for the half-shaft, the kit didn't even come with a template. You can honestly do this by trial and error, the amount you take off isn't a danger to the block or the pan.
Honestly, I would just wait until you get your transmission. It's the only way to be sure.
Old Feb 9, 2008 | 08:13 AM
Ls1 FD3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so it's the same with QSD's kit, and all I did was grind away until I made enough room for the half-shaft, the kit didn't even come with a template. You can honestly do this by trial and error, the amount you take off isn't a danger to the block or the pan.
Honestly, I would just wait until you get your transmission. It's the only way to be sure.</TD></TR></TABLE>
Sounds good, thats what i'l do then. Just wanted to hear from others before i go to town on this block, haha.
Old Feb 9, 2008 | 08:45 AM
gibsanez's Avatar
Good stuff Just remember to throw some silicone on the area you grind off for extra protection.
Old Feb 9, 2008 | 03:52 PM
.Hatches.'s Avatar
ya man make sure you wait till the tranny gets there. good luck
Old Feb 11, 2008 | 12:47 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">****, just realized i left the word "pan" out of the title </TD></TR></TABLE>
fixed
Old Feb 13, 2008 | 07:42 AM
Ls1 FD3s's Avatar
Default Re: Evolution H2B kit, alum or steel oil required? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
fixed </TD></TR></TABLE>
Thank you sir!
delslow45
Apr 3, 2011 07:14 PM
killerpenguin21
16
Dec 16, 2007 09:26 PM
josh0407
Aug 24, 2007 04:30 PM
fandango
Jan 20, 2005 06:20 PM
TheYellowDart
Dec 17, 2004 07:51 PM
