code 41 o2 sensor wtf?
Old Feb 7, 2008 | 03:26 PM
jasony0630's Avatar
Default code 41 o2 sensor wtf?
my car is a 1999 civic ex that just got a b16a3 transplant and converted to obd1 via jumper harness, its throwing a code 41, which is the primary heated o2 sensor....any ideas on how to fix this?
i dont think that the o2 sensor on the cat is the primary, correct me if im wrong, but that one is not plugged in.
and from what i understand the problem is coming from the o2 sensor directly behind the cat.
thanks
Old Feb 7, 2008 | 03:33 PM
z6hatchboy's Avatar
Default Re: code 41 o2 sensor wtf? (jasony0630)
The primary o2 is the first one, i think its on the header. Try replacing it, i dont know if its possible that you have connected the primary o2 into the secondary and its now throwing the 41.
Old Feb 7, 2008 | 04:22 PM
jasony0630's Avatar
when i checked, there were only 2 o2 sensors total, once on the cat that plugs in with the eingine wiring harness, and the other one is on the exhaust pipe that has wires running into the cabin...
Bossup!
Sep 9, 2009 07:35 PM
jxkim89
Dec 30, 2006 02:55 PM
07civicEF
Aug 8, 2006 04:44 PM
EF8IGHT
Jan 10, 2006 02:52 PM
wootcivic
Nov 29, 2004 10:01 AM
