How do you?
Old Feb 7, 2008 | 01:52 PM
em12nv's Avatar
Default How do you?
Anyone know how to install side markers on a em1, with a relay. I know you need one relay for each side. Correct me if im wrong. Anyone help is good.
Old Feb 7, 2008 | 02:05 PM
InfamousDelSol's Avatar
Default Re: How do you? (em12nv)
Relay? Hemm i dont know about that one, but i do know that you just connect 2 wires to your corner lights and you can ether connect the sidemarker to blink or running lights. Go to search and type in sidemarker, you should have abunch of results.
Old Feb 7, 2008 | 02:10 PM
em12nv's Avatar
Default Re: How do you? (InfamousDelSol)
I search but didnt find out how to wire them up to an em1. Maybe I try searching on em1crew .com
Old Feb 7, 2008 | 03:14 PM
Padawan's Avatar
Darth ModerVader
You don't need relays. Just tap the side marker wires into the turn signal wires.
Old Feb 7, 2008 | 03:23 PM
wangkata's Avatar
you don't need relay... I didn't just tap ur corner light anyway check this out.....
https://honda-tech.com/zerothread?id=1928843
http://members.***.net/ninety2...r.htm
Old Feb 7, 2008 | 05:46 PM
em12nv's Avatar
Default Re: How do you? (wangkata)
OK, got it done, about 30 mins ago, but when I arm my alarm the side markers dont light up. They do work good, looks nice. I connected them to the green and black one. Which one or how do I connect it so that when I arm the alarm they flash.
Thanks for the help guys.
Old Feb 8, 2008 | 01:25 PM
em12nv's Avatar
Anyone
Old Feb 8, 2008 | 02:09 PM
pdiggitydogg's Avatar
you dont wire them that way...
If you connected them to flash with the alarm, they would be on whenever the parking lights are on - which is wrong.
They are only supposed to flash when signalling.
Old Feb 8, 2008 | 03:08 PM
julianaa's Avatar
I wired my foglights to the red wire on my corners, and they light up whenever I set my alarm
Old Feb 8, 2008 | 08:30 PM
Then they dont flash when signaling
CDelgado220
Lighting
Aug 2, 2011 06:52 AM
Samonoske
Jun 15, 2010 10:57 AM
Karado58
Audio / Security / Video
14
Oct 14, 2009 12:06 AM
DsVtec2nrHBC
Feb 2, 2005 05:59 PM
crxtreme27
Jun 10, 2003 10:03 PM
