keyless entry help
Old Feb 2, 2005 | 09:42 AM
DsVtec2nrHBC's Avatar
Default keyless entry help
ok.. so i put in my keyless entry a couple of months ago and no problem from it..
then i finally got a relay a couple of weeks ago to make the parking lights flicker with it.. so i was all happy yay..
well the first weel.. ti worked fine
but now all fo a sudden the lights dont flicker anymore? the door still shuts and unlocks.. the parking lights still work besides the keyless entry.. is it maybe that the relay is blown? or that the relay is not getting enough power.. cause my whole keyless entry runs off the same like thin wire from my battery? do i need a thicker wire for all of it?
thanx
Old Feb 2, 2005 | 12:08 PM
B18C_EJ8's Avatar
Try replacing the relay.
Old Feb 2, 2005 | 05:59 PM
screaminvtec's Avatar
Default Re: keyless entry help (DsVtec2nrHBC)
how did u wire relay and what type of keyless are you using. if you are tring to reverse the polarity you want 12volt going to 87 and 86 of the relay, 85 is your negative input from keyless, and 30 out to your positive parking lights. thats how i do it when i install keyless in a car that has positive parking lights and negative trigger from keyless.
KernelBadness
Honda Civic (2001 - 2005)
Jun 29, 2014 12:17 PM
hamorhead
Lighting
Sep 19, 2008 05:45 AM
turbotime
Apr 30, 2007 05:45 PM
oranginal
May 21, 2006 07:31 PM
pdiggitydogg
Audio / Security / Video
Mar 15, 2003 12:37 PM
