HELP! Installed Skunk2 70mm throttle body and Intake Manifold on 2000 Civic SI, Vtec engagement as
Hi. I just installed a skunk2 70mm throttle body and intake manifold on my 2000 Civic Si. its a 1.6L DOHC Vtec, and I installed this about a month ago. There are no oil leaks, no vacume leaks, everything is tight and runs fine. Its just that i have had this car for a while and before i installed these 2 mods, the vtec would always engage at 5500rpm. Now it doesn't engage until 6200rpm. Is there a possibleity that the extra air would change the air/fuel ratio causing the vtec to change?? I am lost and have searched for this forever. I have heard of a few posts on other sites where the manifold caused a problem with a secondary runner or something and the vtec would change?? i don't know. I am just curious if there is a fix for this or if I need to change the timing advance/retard or if its right in front of my face and i just don;t see it...... any help would be great! thanks
send2artem
Jul 17, 2011 09:03 PM
importech24
Jan 26, 2008 07:49 AM
