p72 ecu with B18c5 motor
I just installed a b18c5 and i currently cannot run the obd2b itr ecu because my car is obd2a. I do have a p72 ecu from my car. I have read that the mapping is almost the same. So is it ok for me to run this ecu or should i look at buying an obd2a p73?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr »</TD></TR><TR><TD CLASS="quote">that's right, vtec engagement is 4500 on gsr? With a chipped obd1 ecu would i still be able to pass smog/emissions?
Thanks for the response.</TD></TR></TABLE>
I honestly never went to smog with a chipped ecu. But maybe if you put the exact same map for the itr into the p28, you may be able to pass smog.
