LS-T Turbo Setup .. whatcha think?
Old Feb 6, 2008 | 06:27 PM
90turbosi's Avatar
Default LS-T Turbo Setup .. whatcha think?
I was wondering if i was doing this build right and trying to get a good estimate on what kind of power ill make on a 93 octane tune ..
My build consists of :
Bore to 2.0L 84mm
Crower turbo cams
Crower titanium retainers
Crower oversized valves
Port and polish
3 angle valve job
JE 84mm. Pistons
8.5 to 1 Compression
Eagle Rods
Darton Sleeves
Skunk 2 Intake Manifold with ported Throttle Body
Drag Turbo Manifold
Tial 38mm. Wastegate 8psi spring
Spa T70 Turbo .63 AR
S-max Intercooler with CO2 Sprayer
Turbo XS Manual Boost Controller
AEM Fuel Rail
AEM Adj. Cam Gears
Walbro 255lph fuel pump
1000CC RC Injectors
AEM Uego Wideband Controller
ARP Head studs
Cometic Gasket Set
Koyo Half-Radiator with Flex-a lite Fan
Aeromotive A1000 Fuel Pressure Regulator
AEM P2P Engine Management System
AEM 3Bar Map Sensor
Nology Spark Plug Wires
NGK Spark Plugs
MSD 7AL with Blaster Coil
Old Feb 6, 2008 | 06:31 PM
HondaCivicSiR1's Avatar
Default Re: LS-T Turbo Setup .. whatcha think? (90turbosi)
take a look in here
https://honda-tech.com/zerothread/1323059
Old Feb 6, 2008 | 06:34 PM
90turbosi's Avatar
Default Re: LS-T Turbo Setup .. whatcha think? (HondaCivicSiR1)
i read through most of it and i dont really answer my question
Old Feb 6, 2008 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90turbosi &raquo;</TD></TR><TR><TD CLASS="quote">i read through most of it and i dont really answer my question </TD></TR></TABLE>is this set up for a daily driver or track car?since you want a bore it to 84mm look at the boosted b20 thread. no one can really tell you what you what kind of power you are to going make.build it and get it tuned
Old Feb 6, 2008 | 06:40 PM
90turbosi's Avatar
i did build my motor already just prepping my car for the install ... and its being street driven and a track car
Ckirk
18
Dec 14, 2018 10:33 AM
streetracer6rpt
Jun 18, 2007 07:12 PM
DC2tuner
Aug 4, 2005 04:15 PM
B18 CYA
May 22, 2004 11:22 AM
(__________)
Aug 27, 2002 09:56 PM
