Question about auto b18b into manual EG
Old Feb 6, 2008 | 01:10 PM
slacks's Avatar
Default Question about auto b18b into manual EG
I'm looking into a b18b out of someone's parted teg, but it's an automatic.
I was wondering what could be used along with an LS manual tranny. Could the same clutch/flywheel, engine harness, mounts, throttle cable and axles be used for my manual EG?
What else is needed to get this done?
Old Feb 6, 2008 | 01:14 PM
crazyguy's Avatar
Default Re: Question about auto b18b into manual EG (slacks)
any b series hydro tranny will fit. for the mounts. u will need to get from a 94 and up integra, and rear t bracket , intermediate shaft axle and both cv axles too..throttle cable.u will need to get from a LS integra. GRS wont wrok. and a p75 ecu
Old Feb 6, 2008 | 01:17 PM
slacks's Avatar
Default Re: Question about auto b18b into manual EG (crazyguy)
everything is coming from a 99 integra LS so there's no problem, just wasn't sure if the mounts and throttle cable was different.
Old Feb 6, 2008 | 03:29 PM
slacks's Avatar
bump!
anyone know if i can use the same engine harness, starter and these other components! i need to let them know if it's going to be bought tonight!!
Old Feb 6, 2008 | 03:55 PM
slacks's Avatar
Default Re: (slacks)
post cake bump
Old Feb 6, 2008 | 05:57 PM
instrument's Avatar
do they still have cheerleading competitions at vorhees high? those things were so hot!
go warren hills!?!!?!?!
the harnesses are the same, starter is the same, of course the throttle cable is the same.wtf.
Old Feb 7, 2008 | 01:25 AM
slacks's Avatar
Default Re: (instrument)
the starter for an auto will fit a manual?
Old Feb 7, 2008 | 01:28 AM
watsvtecEK's Avatar
You will need mounts from a manual integra, auto wont work. and the starter is different too.
Old Feb 7, 2008 | 10:46 AM
slacks's Avatar
Default Re: (watsvtecEK)
thank you, that's an answer i was looking for.
b15
13
Jan 16, 2010 04:47 AM
Ahknodd
May 18, 2009 05:17 PM
slacks
Feb 7, 2008 12:51 PM
HFpower
Sep 23, 2006 12:00 AM
93b18civic
May 15, 2004 01:31 AM
